Author Topic: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol  (Read 1199439 times)
Offline Altemir
  • Country: ru
Re: REVIEW - Rigol DS2072 - First Impressions of the DS2000 series from Rigol
« Reply #2225 on: January 20, 2014, 04:57:10 pm »
Hi guys.
Anyone know how much memory uses the DS2072 to estimate the FFT?
Thanks.  ;)
Rigol said only 2048 dots :(
Offline Carrington
« Reply #2226 on: January 20, 2014, 05:29:47 pm »
Not so bad.
Thank you very much.
My English can be pretty bad, so suggestions are welcome. ;)
Space Weather.
Lightning & Thunderstorms in Real Time.
Offline marmadTopic starter
  • Country: aq
    • DaysAlive
« Reply #2227 on: January 20, 2014, 05:40:13 pm »
Not so bad.
If you don't need to do it real-time, you can do it externally with as many sample points as you want.
Offline Carrington
« Reply #2228 on: January 20, 2014, 05:42:48 pm »
Yes, using something like this:
Space Weather.
  • Country: aq
    • DaysAlive
« Reply #2229 on: January 20, 2014, 05:45:24 pm »
Or this:
Offline Carrington
« Reply #2230 on: January 20, 2014, 05:49:50 pm »
@marmad: Is this your software? Because doesn't seems Matlab.
Space Weather.
  • Country: aq
    • DaysAlive
« Reply #2231 on: January 20, 2014, 05:56:40 pm »
No, someone else - it's posted elsewhere in this forum: wfm_view
The only thing is that it requires the old WFM format (from the DS1000), but my upcoming version of RUU saves sample memory in old WFM format - so no problem ;)
Offline Carrington
« Reply #2232 on: January 20, 2014, 06:00:55 pm »
I get it.  ;)
But why did not you use LabView or CVI to implement your software? Many advanced graphics functions are already made. :-//
http://www.ni.com/lwcvi
« Last Edit: January 20, 2014, 06:16:28 pm by Carrington »
Space Weather.
Offline Carrington
« Reply #2233 on: January 20, 2014, 06:10:54 pm »
I've been researching a bit. I don't know if anyone else has been wondering, who designed this equipment (DS2000 Series).
Well, this is all that I could find:
http://www.rdmag.com/award-winners/2012/08/complex-waveforms-simplified
http://www.rdmag.com/award-winners/2011/08/new-playing-field-gigahertz-oscilloscopes
I figure that these people may be part of the team.
Space Weather.
Offline neslekkim
  • Country: no
« Reply #2234 on: January 20, 2014, 06:57:01 pm »
I get it.  ;)
And labview is free software?
Offline Carrington
« Reply #2235 on: January 20, 2014, 07:05:09 pm »
I get it.  ;)
NO.  ::)
LOL...
Space Weather.
Offline Carrington
« Reply #2236 on: January 20, 2014, 08:54:41 pm »
I'm waiting for the DS2000A with LA.
The Rigol MSO4000 has a sampling rate of 1GSPS for the LA. And I think that the DS1000D series LA has a sampling rate of 200MSPS.
I'm wondering if the DS2000A's LA will have a sampling rate of 500MSPS or 1GSPS.
Anyone know anything about it?
Thanks.
Space Weather.
Offline Mark_O
« Reply #2237 on: January 20, 2014, 11:39:55 pm »
That would seem to be their logical next new-product announcement.  Perhaps mid-year.
That's correct.
Most likely 500 MSa/s.  Think about it.
No, nothing at all.
Offline AndersAnd
« Reply #2238 on: January 21, 2014, 12:53:09 am »
I get it.  ;)
NO.  ::)
LOL...
Neither is extra BW, trigger and decoder options etc. for Rigol products...
Offline m-joy
« Reply #2239 on: January 21, 2014, 08:18:44 am »
what is the name of the software?
Offline neslekkim
  • Country: no
Online pascal_sweden
  • Country: no
« Reply #2241 on: January 21, 2014, 02:49:04 pm »
Thanks.
Are there any rumours or confirmations about upcoming DS2000 series with built-in LA?
Will the LA have 8 channels or 16 channels? When is it expected? Details on launch date and model numbers? Pictures?
Offline Carrington
« Reply #2242 on: January 21, 2014, 03:11:02 pm »
My speculations:
  - Upcoming DS2000 series with built-in LA? Yes, no doubt!
  - Model numbers: DS2072AD, DS2102AD, DS2202AD and DS2302AD.
  - LA 8 Channels at 1GSPS.
  - Launch in the EU, 6 months after it is launched in China.
https://www.eevblog.com/forum/testgear/rigol-ds2000-series-model-designation/
https://www.eevblog.com/forum/testgear/rigol-ds2000-hardware-version-2-0/msg270640/#msg270640
« Last Edit: January 21, 2014, 03:15:53 pm by Carrington »
Space Weather.
Offline branadic
  • Sounds like noise
« Reply #2243 on: January 23, 2014, 07:15:29 pm »
Received two DS2202A this week for our company, including the offical options Deep Memory and Decode.
Thanks to this thread I was able to successfully update both devices to the latest firmware. I'm really happy with this new hardware version and the integrated 50R termination.
In return some old analog 20MHz HAMEG scopes were rejected, that's a fair deal :)
branadic
Computers exist to solve problems that we wouldn't have without them. AI exists to answer questions, we wouldn't ask without it.
Offline NikWing
« Reply #2244 on: January 24, 2014, 06:56:55 pm »
maybe you've found that out already: if you switch off while the screensaver is active, it'll also be active when you switch DSO back on (that means they actually store a "screensaver is active" value somewhere? really odd IMO
Offline Circlotron
« Reply #2245 on: January 25, 2014, 11:55:26 am »
Not sure if anyone else has seen this yet - Each trace has a pointer at the edge of the screen identifying it as CH1 or CH2. With no signal in, CH2 trace lines up perfectly with CH2 pointer and so the offset reading of the trace (if any) corresponds with the trace position. For CH1 the pointer and the trace are offset by several pixels so the offset reading and the trace position are different. For example the pointer might be offset three divisions and the reading shows 3.00 volts offset but the trace is not directly over the graticule line. This is after the scope has calibrated itself after running about 6 hours. What's more, this offset of CH1 trace varies as you turn CH2 off and on.
  • Country: aq
    • DaysAlive
« Reply #2246 on: January 25, 2014, 12:37:12 pm »
Actually, on my DS2000 it's the opposite: with no input, CH2 is offset by a few pixels.
I haven't calibrated my DSO for awhile, but the slight offset of CH2 does not change with CH1 being turned on and off. But as long as the DSO is aware of the offset (i.e. it's included in any measurements), I don't think it particularly matters. To check if there is an offset between the pointer and what the DSO perceives as ground, set the coupling to GND.
  • Country: aq
    • DaysAlive
« Reply #2247 on: January 25, 2014, 12:52:56 pm »
Here are my maximum offsets at the lowest voltage scale. You can see the slightly larger offset in CH2's stats:
EDIT: BTW, the channel pointer is supposed to point to ground - not the input signal level. If there is offset, the trace shouldn't line up with the pointer.
« Last Edit: January 25, 2014, 01:02:06 pm by marmad »
Offline Circlotron
« Reply #2248 on: January 25, 2014, 01:05:21 pm »
Okay.
I've taken a video and trying to compress it to a reasonable size to upload to youtube.
Offline Circlotron
« Reply #2249 on: January 25, 2014, 01:16:53 pm »
Okay.
Righteo, here it is, 273MB compressed to 13MB for the sake of upload.
http://youtu.be/6OQOK85-r0c
