Author Topic: First picture on EEVblog of the new R&S MXO4 series oscilloscope :)  (Read 66446 times)
Offline pdenisowskiTopic starter
  • Product Management Engineer, Rohde & Schwarz
    • Test and Measurement Fundamentals Playlist on the R&S YouTube channel
It's been sitting in my office for weeks, but now that it's been officially launched, I'm officially allowed to share  :)
Test and Measurement Fundamentals video series on the Rohde & Schwarz YouTube channel:  https://www.youtube.com/playlist?list=PLKxVoO5jUTlvsVtDcqrVn0ybqBVlLj2z8
The following users thanked this post: nikifena, egonotto, thm_w, Bud, Muxr, Rich@RohdeScopesUSA, Markus2801A, luudee, fichamba
Online Someone
    • send complaints here
Re: First picture on EEVblog of the new R&S MXO4 series oscilloscope :)
« Reply #1 on: September 27, 2022, 11:46:20 pm »
Nice to see manufacturers continuing to push the envelope of specifications in multiple directions (not just a one trick pony), including details like more offset range.
Do share pricing when you can.
The following users thanked this post: Rich@RohdeScopesUSA, pdenisowski, RBBVNL9
Online TheDefpom
  • YouTuber Nerd - I Fix Stuff
    • The Defpom's Channel
« Reply #2 on: September 27, 2022, 11:46:39 pm »
R&S could send me one to review… just sayin 🤓
Cheers Scott
The following users thanked this post: Rich@RohdeScopesUSA, salvagedcircuitry, RBBVNL9
« Reply #3 on: September 28, 2022, 12:09:29 am »
I'd send you mine if I didn't already have a huge list of things I need to do with it :)
Offline nctnico
« Reply #4 on: September 28, 2022, 01:43:34 am »
The specs look really good! Full HD resolution screen as well.
Just wondering whether this model also uses decimated data for math or that it is possible to use the actual acquired data.
Offline 2N3055
  • Country: hr
« Reply #5 on: September 28, 2022, 04:25:02 am »
Decimation (assuming there are excess samples, of course) always occurs before any math processing*, and I believe this is the case for all digital oscilloscopes.
Nope, it doesn't occur always before any math processing and is not the case for all digital oscilloscopes.
Nice looking machine!! Looking forward to more info!
Dr. Richard W. Hamming
The following users thanked this post: JPortici
Offline tv84
  • Country: pt
« Reply #6 on: September 28, 2022, 08:49:52 am »
The USB ports casings looks cheap. No matter what you say, R&S could have done much better.
Otherwise it looks good and I expect it to be a new comparison reference. Let's see the price.
« Reply #7 on: September 28, 2022, 10:57:34 am »
I've attached the data sheet of the MXO4.
There is also a nice brochure online (19.1MByte).
Can be downloaded here.
« Reply #8 on: September 28, 2022, 11:00:08 am »
AlliCE has some prices online:
https://allice.de/rohde-schwarz/rohde-schwarz-msox4-oszilloskope-mxo44-next-generation-oscilloscope/
Edit:
Screenshot:
« Last Edit: September 28, 2022, 11:02:59 am by BU508A »
Offline Domitronic
« Reply #9 on: September 28, 2022, 11:23:46 am »
This really looks nice and interesting. Will there be more options available like Ethernet compliance tests? Right now there are only some serial decoders, AWG and bode plot.
Offline tv84
  • Country: pt
The following users thanked this post: egonotto, thm_w, tooki, jusaca, Exosia, Weston
Offline Domitronic
« Reply #11 on: September 28, 2022, 12:23:59 pm »
As usual, it was a nice ride while it lasted. :)
Well, if you compare the 200MHz version its "only" a factor of 2 compared to a Siglent SDS2204X HD  ;)
Honestly, i think the pricing is decent when compared to Tek Series 4 or Kesight 4000. Lecroy 4000HD might be a lot cheaper due to special offers but not with regular pricing.
Offline nctnico
« Reply #12 on: September 28, 2022, 12:32:10 pm »
No. For example: GW Instek, Lecroy, Siglent and Tektronix use the acquired data to perform math on. Typically you can choose to do math on the full memory record, the screen portion or between cursors. This means that regardless of the zoom level, you always get the same result from measurements and math. When I did testing of the filter functions on the RTM3004, I noticed that these show odd behaviour due to decimating the data. The decimation makes the filter functions far less usefull. I get that decimation makes doing measurements & math faster but it also means data is being thrown away and it makes it necessary to hint the user that the results may not be accurate.
« Last Edit: September 28, 2022, 12:35:32 pm by nctnico »
Offline Rich@RohdeScopesUSA
« Reply #13 on: September 28, 2022, 02:03:45 pm »
Early look and teardown by AddOhms for those interested:
We're working to get Dave and Shahriar permanent units as well - we're still starting to get them shipped out.  Hope they'll have them shortly (@Dave - Tristen will be in touch if he hasn't already been).
-Rich
« Last Edit: September 28, 2022, 02:05:33 pm by Rich@RohdeScopesUSA »
The following users thanked this post: nctnico, BU508A, Micke, salvagedcircuitry, citizenrich
Offline maxwell3e10
« Reply #14 on: September 28, 2022, 02:57:01 pm »
If the waveform update rate is really high for all settings then this maybe the first scope that has both high resolution and fast waveform update rate (>1 MS/sec). My question would be how fast it can perform waveform average? Maximum is 16M averages, how long would that take?
« Last Edit: September 28, 2022, 03:31:54 pm by maxwell3e10 »
Offline Black Phoenix
  • Country: hk
« Reply #15 on: September 28, 2022, 05:12:46 pm »
-Rich
I could use a permanent unit too...
Joking, I'm no one of influencer or reviewer to have a brand send me something that although I have use for I can't show, so no increasing sales for the brand.
Although yes it would be good to have one...
« Last Edit: September 28, 2022, 05:17:21 pm by Black Phoenix »
Offline nctnico
« Reply #16 on: September 28, 2022, 05:23:24 pm »
And don't forget deep memory... Keysight is having a very bad day today.
Offline Domitronic
« Reply #17 on: September 28, 2022, 05:43:06 pm »
-Rich
In the video he says this is a replacement of the RTA4000 series. Would be nice to see some of the technology trickle down to a future MXO 3 or MXO 2 series if they also plan to replace RTB2000 and RTM3000.
« Last Edit: September 28, 2022, 05:44:53 pm by Domitronic »
« Reply #18 on: September 28, 2022, 06:29:11 pm »
-Rich
I can't talk roadmap, but we've been pretty open about this scope being "the first" of a new generation using this chipset.  So read from that what you will  ;D
-Rich
« Reply #19 on: September 28, 2022, 06:30:28 pm »
Sadly, I don't even have one yet.  Maybe @pdenisowski can test that?  If not, I'll get an answer for you as soon as I get my hands on one.
-Rich
The following users thanked this post: maxwell3e10
« Reply #20 on: September 28, 2022, 06:36:04 pm »
The offset range is a great catch - it will be overlooked with all the speed discussion, but is critical in many applications.
Pricing for the US starts at $8,435 for a 200MHz, 4ch model (sorry - don't have other countries).
-Rich
Offline nctnico
« Reply #21 on: September 28, 2022, 06:39:09 pm »
I agree with that. A limited offset range is something I run into regulary on various oscilloscopes.
Online Martin72
  • Testfield Technician
« Reply #22 on: September 28, 2022, 06:55:59 pm »
Batronix (Germany/EU) got them too:
https://www.batronix.com/shop/oscilloscopes/Rohde-Schwarz-MXO44-242.html
I must confess, this is really an eyecatcher - But far, far away for me... 8)
Online Fungus
« Reply #23 on: September 28, 2022, 07:38:44 pm »
Wait 'til you add a few "accessories" like serial decoders, the AWG, or heaven forbid ... a bandwidth upgrade.  >:D
Is the Siglent HD hackable? I'm betting the R&S isn't.
Online Martin72
« Reply #24 on: September 28, 2022, 07:46:12 pm »
Comparison is the end of happiness and the beginning of dissatisfaction
(Kierkegaard)
 8)
The following users thanked this post: BU508A, balnazzar
