Products => Test Equipment => Topic started by: qball on December 30, 2022, 12:11:45 pm
I received a siglent DMM today, after installing I noticed I got the IP address from a siglent signal generator.
Turns out these devices both have the same mac address, so my router hands out the same ip to them.
I tried searching if I can change it but so far no luck, I can give on a fixed ip, but I strongly prefer to have it centrally managed.
Does anybody know if siglent has a (hidden) command to change the mac address?
(DMM is the SDM3065X)
:palm: for Siglent! Yes you can assign it a fixed IP but if both the DMM and the signal generator are powered your switch will get very confused, they normally maintain a table which MAC address is on what port. I highly doubt that you can change it yourself and personally I would send it back to have it swapped, hoping that you don't receive one with the same problem.
:palm: :scared:
Siglent quality.
Siglent quality.
Nahh... they probably sold more than 4B devices and now are reusing... :-DD
A fixed IP won't work because the MAC address is what is used to direct traffic on a local network. Your only option is to return the DMM for a replacement. Make clear to the supplier that this particular DMM can not be used on your network and that you will need a different one.
Yeah, but what are the odds that a different meter doesn't have the same mac-adress? :popcorn:
Same here (https://www.eevblog.com/forum/testgear/siglent-sdm3055-dhcp-mac-address-problem/msg3210170/#msg3210170).
Maybe it's possible to change it with the SCPI command:
:SYSTem:COMMunicate:LAN:MAC
I don't remember anyone trying...
Offically any piece of equipment with an ethernet interface should have the MAC address printed on the outside (on a sticker). So it should be easy to check by the supplier. Ofcourse there is always the possibility the manufacturing process at Siglent is somehow broken and all units are shipped with a factory default address. Easy to find it if the actual MAC address differs from what is printed on the sticker.
