Author Topic: Flaw direct from Tektronix factory  (Read 4661 times)
Offline JwallingTopic starter
  • This is work?
« on: August 10, 2017, 02:50:52 pm »
While working on a TDS7104A I noticed that the 1M and 50Ohm LED indicators for CH1 were not working.
Figured it was a couple of bad LED or the driver.
Nope. It shipped like this originally from the factory. I can't believe they didn't catch this!  :palm:
Jay
System error. Strike any user to continue.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Flaw direct from Tektronix factory
« Reply #1 on: August 10, 2017, 07:03:51 pm »
Yeah but now the warranty is void.  :box:
Odd that that missed inspection though.  Humans, whaddya gonna do?
Seven Transistor Labs, LLC
Offline tautech
« Reply #2 on: August 10, 2017, 07:08:53 pm »
  • This is work?
« Reply #3 on: August 10, 2017, 07:10:18 pm »
Yeah! I got a repair quote for $6950.  ;)
Jay
  • This is work?
« Reply #4 on: August 10, 2017, 07:13:34 pm »
xrunner found another here:
I could sort of see how that one could get by... For a while anyway. No vibration testing, and it probably was making contact OK during test.
Jay
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #5 on: August 10, 2017, 07:29:53 pm »
Yea that was on a PG501 plug-in. The output wasn't working when I got it, but it had a cal sticker on it. It may have been touching just enough a long time ago. But yea, somebody was anxious to get off work that Friday at the factory and get to happy hour!  :-DD
Offline hendorog
« Reply #6 on: August 10, 2017, 07:32:11 pm »
A good example showing Testing and Quality are not the same thing. Quality happens when something is built.
I wonder what percentage of scopes are tested off the production line?
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #7 on: August 11, 2017, 05:45:08 am »
Indeed.
LeCroy runs every scope through an extensive test process, and as far as I know Keysight and R&S  do the same.
But don't forget that for many years Tek had to suffer under Danaher, who's main method of revenue generation was excessive cost cutting (DBS, Danaher Business System).
The following users thanked this post: hendorog
Offline Paul Moir
« Reply #8 on: August 11, 2017, 06:43:02 am »
Doesn't matter.  As T3sl4co1l alluded, if it's humans doing the testing they will fail sometimes.  We just aren't cut out for that kind of work.
« Reply #9 on: August 11, 2017, 09:04:49 am »
Which is why reputable manufacturers usually have processes and systems in place to mitigate for the 'human element'.
Such processes are also part of ISO9000 certification.
Online coppice
« Reply #10 on: August 11, 2017, 11:18:28 am »
As long as you put in writing "we do really shitty half baked things", and you actually do shitty half baked things, you get ISO9000 certification. I thought the myth that ISO9000 was about achieving high quality had faded away years ago. Its only about achieving consistent results, whether they be consistently good or consistently horrible.
« Reply #11 on: August 11, 2017, 11:23:01 am »
True. My father's company is ISO 9001 cert and he's a total cowboy two man band IT outfit. It means nothing other than you prepared documentation to their standards and can fudge some lies on audit.
ISO 27001 is the same turd in the security space.
« Reply #12 on: August 11, 2017, 11:27:16 am »
I never said ISO9000 was about highest quality, it's as you say a tool for making sure results are constant with little variations. But part of that is the understanding that avoiding errors in the first place will reduce subsequent costs which would be spent on rectifying stuff. Which is why most of the reputable manufacturer try to get end control right.
Offline T3sl4co1l
« Reply #13 on: August 11, 2017, 01:30:15 pm »
No warranty for obvious factory mistakes?  Ouch!
Statistics, it's a wonderful thing, but must be applied properly to be beneficial.  (Or, inappropriately, as befits an agenda, as is so often the case...)
It's true that some things can't be tested into quality; it's interesting that some things can.  That was what they said about early semiconductors, but lo and behold, a production line making 2% yield still made good parts.  Just not many!  On the other hand, tests that aren't triggered by the underlying failure (or which are unreliable, like human inspection) don't improve quality very much.
A lot of production errors (like soldering defects) can similarly improve quality by inspecting for them; but the inspection needs to be thorough and reliable (e.g., machine AOI versus semi-automated human inspection).  On the other hand, an electrical test helps a lot, but is not complete (for one example, I've seen a board with D2PAK head-on-pillow solder defects -- enough to make contact, but no good thermally, so they cooked).
Offline T3sl4co1l
« Reply #14 on: August 11, 2017, 01:34:12 pm »
The Dilbert effect. ;D  (Well, one of them.)
Offline PartialDischarge
« Reply #15 on: August 11, 2017, 01:43:41 pm »
Not bad, recently I asked for a quotation of all 15 knobs in that scope. 7 of one type + 7 smaller ones + the small trigger one. 25€ each + taxes. Nearly 500€ all of them  :-DD
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #16 on: August 11, 2017, 04:39:19 pm »
We definitely run 100% of our oscilloscopes through hardware tests and performance characterizations. I can't fathom not testing every unit, but I haven't seen their production lines so  :-//
Offline alm
« Reply #17 on: August 11, 2017, 06:17:53 pm »
Humans are fairly bad at staying alert at things that only go wrong only 0.1% of the time. Which is why they introduce fake weapons at security checkpoints to keep the X-ray operators alert. I imagine having the LEDs blocked by the case is quite rare, so it would not surprise me if it did go through QA inspection but the inspector failed to catch it because they were more focused on other parts that fail more often, like performance issues. Also the failure would not be obvious to an inspection for external defects while powered off.
The following users thanked this post: wraper
Offline Paul Moir
« Reply #18 on: August 11, 2017, 06:37:27 pm »
I had three levels of verification miss an obviously incorrect label in a very ridged quality system.  Now a computer scans a barcode.  You do anything enough and you'll find that humans are at best 99%, and are far worse than that if they don't expect to see the problem.  Their strengths are elsewhere.
  • This is work?
« Reply #19 on: August 11, 2017, 07:39:45 pm »
I bought some in the last few months from Tek. $12USD each. Still pretty painful.
Jay
Offline Electro Detective
« Reply #20 on: August 12, 2017, 12:55:13 am »
It pays to 'Take It Apart' especially nowadays, on any gear you rely on,
or fingers crossed and pray yours didn't come off the assembly line on Friday afternoon   :clap:
or Monday morning   :(
I've seen and sorted out some unbelievable whoppers   :wtf:
and the times I contacted the companies direct about it to point out the issue/s, AND offer a simple fix suggestion at no cost to them or production delays..
well, talking to their rear brick wall would have gotten better results   |O
One large lot of recalled electrical fittings I suspect went into landfill rather than just simply undo 2 housing screws,
and reverse the neutral and earth/ground wires on the terminal block (2 screws) so it would comply with electrical codes it got approval with in the first place  ::)  and not trip RCD/GFCIs
i.e. with a small power screw driver at the correct torque/clutch setting, probably get it done in under a minute per unit
Instead it was easier for them to landfill the lot   :palm: :palm:
FWIW, I kept and fixed mine with a 'no tech' screwdriver in 2 minutes   :clap:
Online coppice
« Reply #21 on: August 12, 2017, 12:18:44 pm »
Do you soak test 100% or your scopes? Even low cost consumer equipment is typically given a 48 hours soak test, with a recheck after the soak. I can't imagine even a low end test equipment maker doing less.
