Author Topic: Rohde & Schwartz FPC1000 Spectrum Analyzer 'gitch'  (Read 662 times)
Offline JohnPiTopic starter
« on: June 12, 2020, 06:08:50 am »
I have an R&S FPC1000 SA. Under some conditions I notice an artifact step in the display at just about 1 MHz. This is not a function of the signals I put in -- in fact it also occurs with no input signal and just a 50 Ω connected to the input. I have seen this step as large as 10 dB in some cases.
It seems this is somehow related to relative values of RBW and VBW settings, and/or the averaging mode, but I can't figure out what.
Here is an example of no input, and (in this case a small step) a step is visible at 1 MHz (not precisely, generally 989 kHz).
1002429-0
Any ideas on what is causing this ?
« Last Edit: June 12, 2020, 06:10:38 am by JohnPi »
Offline TheUnnamedNewbie
  • mmwave RFIC/antenna designer
Re: Rohde & Schwartz FPC1000 Spectrum Analyzer 'gitch'
« Reply #1 on: June 12, 2020, 06:17:34 am »
When I just looked at the picture I thought it was something we see all the time in spectrum analyzers, though usually the other way round (sudden increases in noise-floor) usually when the analyzer mixer switches to a different harmonic. This might be similar, but more a case of an additional block needing to be engaged to measure below 1 MHz? some kind of upconverter?
Is there a block diagram available of the FPC1000?
The best part about magic is when it stops being magic and becomes science instead
"There was no road, but the people walked on it, and the road came to be, and the people followed it, for the road took the path of least resistance"
« Reply #2 on: June 12, 2020, 09:50:31 pm »
No block diagram available from R&S. I have contacted their tech. support; I'll see if they can explain what it is doing.
One thing, while the SA is described a 5 kHz - 1 GHz, DANL (noise level) is only specified about 1 MHz. I hope it isn't horrible below that as that's what I'm most interested in...
« Last Edit: June 13, 2020, 03:41:24 am by JohnPi »
