Author Topic: Fluke 117 'F11- Err' is it possible to repair?  (Read 368 times)
Offline cheboTopic starter
« on: November 21, 2024, 03:05:01 pm »
My Fluke 117 started showing an 'F11- Err' error when turned on. I think his firmware crashed.
It broke after I tried to measure the voltage of its own battery with it. When you touch the minus of the battery with the "-" probe, the display goes out. After several touches, the device began to show this error. (Does anyone want to repeat it? ;))
Is it possible to repair? Maybe replace the controller? They are available on Aliexpress. But it should probably already be programmed for this model?
Experience is what we got instead of what we wanted...
Offline Fungus
Offline BeBuLamar
Re: Fluke 117 'F11- Err' is it possible to repair?
« Reply #2 on: November 21, 2024, 05:37:18 pm »
And also Fluke doesn't repair the 11x series meters. If under warranty they would simply replace it but they said they don't repair them.
« Reply #3 on: November 22, 2024, 08:09:01 am »
Ok, i got it, thanks! )))
