My Fluke 117 started showing an 'F11- Err' error when turned on. I think his firmware crashed.
It broke after I tried to measure the voltage of its own battery with it. When you touch the minus of the battery with the "-" probe, the display goes out. After several touches, the device began to show this error. (Does anyone want to repeat it?
Is it possible to repair? Maybe replace the controller? They are available on Aliexpress. But it should probably already be programmed for this model?
