Author Topic: GPIB library ni4882.dll function ibexpert?  (Read 502 times)
Offline alan.bainTopic starter
« on: November 28, 2024, 09:26:13 pm »
The function ibexpert is defined in the header <ni4882.h> as
PORT unsigned int NI488CC ibexpert (int ud, int option, const void * Input, void * Output);
I cannot however seem to find any documentation for it, but I know that on using VISA viOpen it gets called with ud=-1, option=0xe and Input = Output = some memory buffer.
Does anyone know any more (or have a link) or is this a case for IDA ?
(It looks on very cursory inspection as if it ends up fairly quickly in a giant switch statement on "option").
Alan
Re: GPIB library ni4882.dll function ibexpert?
« Reply #1 on: November 29, 2024, 11:42:35 pm »
Having found out a little more about the function I'd be very interested to see the results of ibexpert for options 10 and 11 on a real NI interface working with ni4882.dll. These return general info and controller into into the buffer Output. So e.g.
char buf1[2048];
char buf2[2048];
ibexpert(0, 10, NULL, buf1); // Returns the "configured interfaces"
DWORD boardId =0; // Valid number of a GPIB NI board
ibexpert(0, 11, &boardId , buf2);
If anyone had a working setup and could try the calls I'd be interested in what was in the buffers afterwards.  To the best of my knowledge they are read only calls.
« Reply #2 on: December 10, 2024, 10:03:01 pm »
For ibexpert call with option 10 turns out this returns an array of size 100 (decimal) DWORDs containing 1 if the ith interface is present and 0 if not.  Option 1 is harder to work out since it seems to involve a virtual function call and that needs a NI interface to actually do anything other than return an error.  So for those normal folk with one GPIB interface id 0 this returns 1 in first element of output and rest of bytes 0.
Offline Tony_G
  • Checkout my old test gear channel (link in sig)
    • TGSoapbox
« Reply #3 on: December 10, 2024, 10:58:30 pm »
I've never used the native API to talk to my adapter (I use the VISA.NET framework) but here is what I got from running:
   char buf1[2048];
   char buf2[2048];
   unsigned long boardId = 0; // Valid number of a GPIB NI board
   ibexpert(0, 11, &boardId, buf2);
buf1 returns exactly what you said and buf 2 returns:
+		buf2	0x00000075557be9d0 "NI GPIB-ENET/1000"	char[2048]
Which is the NI device I use to connect to my devices from my PC.
TonyG
The following users thanked this post: alan.bain
« Reply #4 on: December 16, 2024, 11:38:40 pm »
Thank you very much. This is indeed most helpful.  I've now been able to get my library to talk under VISA to a prologix interface.  Next steps require locating more GPIB cables !
char buf1[256];
int ret = ibexpert(0, 1, NULL, buf1);
This seems to return a DWORD of 0x5b but I'm not totally sure what it means.
char buf2[256];
ret = ibexpert(0, 6, NULL, buf2);
Genuinely curious...
Alan
Offline Tony_G
    • TGSoapbox
« Reply #5 on: December 17, 2024, 03:45:08 pm »
Here is what I get from those, starting with the second one:
   char buf4[256];
   ret = ibexpert(0, 6, NULL, buf4);
This returns the NI Adapter serial number as ASCII in the buffer (my adapter serial number is 0174ACF1):
-		buf4	0x000000871b78f4d0 "0174ACF1"	char[0x00000100]
[0x00000000] 0x30 '0' char
[0x00000001] 0x31 '1' char
[0x00000002] 0x37 '7' char
[0x00000003] 0x34 '4' char
[0x00000004] 0x41 'A' char
[0x00000005] 0x43 'C' char
[0x00000006] 0x46 'F' char
[0x00000007] 0x31 '1' char
[0x00000008] 0x00 '\0' char
[0x00000009] 0xcc 'Ì' char
[0x0000000a] 0xcc 'Ì' char
The call:
   char buf3[256];
   int ret = ibexpert(0, 1, NULL, buf3);
returns:
-		buf3	0x000000871b78f390 "Ù"	char[0x00000100]
[0x00000000] 0xd9 'Ù' char
[0x00000001] 0x00 '\0' char
[0x00000002] 0x00 '\0' char
[0x00000003] 0x00 '\0' char
[0x00000004] 0xcc 'Ì' char
[0x00000005] 0xcc 'Ì' char
Which is a 4 byte return with the first byte as D9 - Sorry - No idea what that is.
TonyG
Offline Tony_G
    • TGSoapbox
« Reply #6 on: December 17, 2024, 04:02:42 pm »
It just occurred to me that I have a genuine NI USB adapter on my voltage monitoring system (which is separate from the GPIB-ENET).
Code is:
   char buf1[2048];
   char buf2[2048];
   char buf3[256];
   char buf4[256];
Results are:
+		buf1	0x0000005b025de370 "\x1"	char[2048]
+ buf2 0x0000005b025deb90 "NI GPIB-USB-HS" char[2048]
+ buf3 0x0000005b025df3d0 "Ö" char[256]
+ buf4 0x0000005b025df510 "01211837" char[256]
with that buf3 still being 4 bytes but now a D6:
-		buf3	0x0000005b025df3d0 "Ö"	char[0x00000100]
[0x00000000] 0xd6 'Ö' char
Still have no idea what it means though.
TonyG
« Reply #7 on: December 17, 2024, 06:04:14 pm »
Well it solves the problem of the call 6 at least. All I could see was
vaPrint(Output, "%08X", *(_DWORD*)SomeData);
I've just got my drop in driver working with VISA talking to an old MI6960.
An invalid response to the ibexpert 1 call gives a VI_ERROR_SYSTEM_ERROR
I did wonder if it was some kind of numerical board id to describe interface type.
