Author Topic: Rigol Trigger Out/Pass/Fail connector.  (Read 3260 times)
Offline ReneTopic starter
« on: November 02, 2014, 08:23:19 pm »
Hello,
I noticed that my Rigol oscilloscope has a BNC connector on the back that is labeled "Trigger Out/Pass/Fail". Just for fun, I wanted to take the signal coming out that connector and plug it into the oscilloscope channel 1 input.
The problem is that I am afraid of taking a BNC cable and directly connecting the two connectors because I don't know if this will hurt the oscilloscope in some way.
Is it safe to just connect the two connectors together via a straight BNC cable or do I need something a little bit more fancy to make that happen?
Thanks.
Offline alex.forencich
    • Alex Forencich
Re: Rigol Trigger Out/Pass/Fail connector.
« Reply #1 on: November 02, 2014, 08:57:41 pm »
If you hooking something up to a scope input channel, there is nothing to worry about.  They break it out as a BNC for convenience so you can do exactly that.  You can also generally run it to the trigger input on the back of a scope, though this can be slightly more fiddly than coming in through a channel input (generally you can only do edge triggering with a fixed threshold).  Generally those outputs are just 0 or 5v, so nothing really to worry about.  And it should be protected against shorts internally with a series resistor.
Python-based instrument control: Python IVI, Python VXI-11, Python USBTMC
« Reply #2 on: November 02, 2014, 09:30:31 pm »
Thanks Alex.
For a second I thought I would have to buy one of those crazy BNC cables with terminators on them so they pretend to be some sort of oscilloscope prove.
By the way, is there a particular BNC spec cable I should get? I keep reading a lot about 50 / 75 ohms and other interesting specifications.
Thanks.
