Author Topic: Aftermarket bench DMM test leads?  (Read 986 times)
Offline iXodTopic starter
« on: December 07, 2020, 09:11:32 pm »
Searching, I see that most meter test leads have right-angle banana plugs. This doesn't work well for a bench DMM: difficult to plug/unplug, interfere with some push-buttons, etc.
What are the recommended aftermarket test leads with straight bananas for this type of meter?
Thanks.
Offline purpose
Re: Aftermarket bench DMM test leads?
« Reply #1 on: December 07, 2020, 09:28:22 pm »
Probe Master sounds right up your street. They offer several options for straight connectors and made in USA.
« Last Edit: December 07, 2020, 09:39:30 pm by purpose »
Offline bdunham7
« Reply #2 on: December 07, 2020, 09:39:15 pm »
I have Fluke TL221 leads and they can be used with a whole slew of ends--the Fluke slim-probes, the TP175E twist-guard probes, the excellent Probemaster test hooks and banana-to-alligator clips that I have a bunch of from Scopemeters.  They can also take those Pomona long-nosed alligator jaw things for electrical panel work, but not to likely to need those on a bench meter.  Probemaster stuff is also nice, but their equivalent test leads have a retractable sheath that is handy in that it will fit ancient DMMs, but I don't think they're as nice otherwise.
