Author Topic: Fluke 187 Fading Display  (Read 3000 times)
Offline Martin72Topic starter
  • Testfield Technician
« on: January 04, 2021, 12:13:29 am »
Hi everyone,
We (Company I work for) got several Fluke Meters, most of them are 87V, some are 187/189.
We let them calibrate every year external and one of the fluke 187 came back with an "error".
So it was sorted out and now it´s mine... :)
It´s failure?
"Only" fading display as I know it from the old Fluke 87 ones.
But cleaning the solder pads won´t make it better.
What else could I clean ?
The zebra stripes ? The display itself or should I better buy new zebrastripes for it ?
Thanks in advance!
Martin
Offline retiredcaps
Re: Fluke 187 Fading Display
« Reply #1 on: January 04, 2021, 02:39:52 am »
Try cleaning the zebra strips and pcb pads that touch it.  See
https://www.eevblog.com/forum/testgear/fluke-187/
for pictures.  Use generous 99% IPA and clean as per
http://mrmodemhead.com/blog/fluke-8x-faded-lcd/
Offline ac_dc
« Reply #2 on: August 01, 2021, 07:58:29 pm »
Hello! I also have a problem with missing segments on a Fluke 189. I would also want to mount the rotary knob on the front panel. Does anyone know how to dismantle it?
Offline shakalnokturn
« Reply #3 on: August 01, 2021, 09:38:31 pm »
The knob snaps into place, once the PCB removed give a good straight push on the end of the axis.
Offline ac_dc
« Reply #4 on: August 02, 2021, 10:14:30 am »
On the middle white plastic axis?
Online Fungus
« Reply #5 on: August 02, 2021, 02:11:56 pm »
Yes. Use something to push that (push hard!)
Offline ac_dc
« Reply #6 on: August 02, 2021, 09:13:33 pm »
OK ... thanks for the hint and I will report!
Offline BeBuLamar
« Reply #7 on: August 02, 2021, 11:08:38 pm »
Hi everyone,
It´s failure?
Thanks in advance!
Martin
And the bad thing is Fluke doesn't want to fix the 189 (although it has a lifetime warranty). They told me to buy the 289 when I sent one in for repair.
Online Fungus
« Reply #8 on: August 03, 2021, 12:59:38 am »
They haven't manufactured a 189 for a long time now, maybe they have no parts.
Offline retiredcaps
« Reply #9 on: August 03, 2021, 02:21:28 am »
Read the definition of lifetime from
https://dam-assets.fluke.com/s3fs-public/187_189_umeng0200.pdf
The following users thanked this post: Fungus, marcus h
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #10 on: August 03, 2021, 01:35:26 pm »
My 189 does not have fading, but bleeding. When something is displayed, some adjacent segments are slightly lit. I suspect the zebra strip degraded and has become slightly conductive.
Offline BeBuLamar
« Reply #11 on: August 04, 2021, 02:38:46 pm »
My 189 is OK but because I used it very little. Perhaps less than 100 hours since I had it in 2004. I hope it won't have the problem. I think I would use it more when I retire as  i would be working more on my own project and not company work which I use company's meters.
Offline retiredcaps
« Reply #12 on: August 04, 2021, 10:20:19 pm »
If you have alkaline AA's take them out.  So many pictures of leaked AAs inside meters.  I use lsd nimh Eneloops in my  187.
Online Fungus
« Reply #13 on: August 05, 2021, 03:22:53 am »
Especially in the 187 and 189 which don't fully power off because they have an internal clock and use about 70uA when they're "off".
The 189 also has a supercapacitor which can leak. Check it out and if there's any leakage you need to remove it before it wrecks the PCB.
Offline Trader
« Reply #14 on: July 25, 2022, 08:16:05 pm »
Do you have any updates?
Hi everyone,
It´s failure?
Thanks in advance!
Martin
« Reply #15 on: July 25, 2022, 08:32:47 pm »
Sorry, forget it....
Yes, I´ve cleaned the stripes and the "contacts" again, in this time with isopropanol, reassembled it...and it works.
(I had bought the isopropanol at the pharmacy. The pharmacist asked me what I wanted to use it for and as I answer for cleaning electrical contacts he said it´s ok for this(it was diluted with 30% water))
