Author Topic: Fluke 189 firmware  (Read 955 times)
Offline rauldmTopic starter
  • Country: mx
Fluke 189 firmware
« on: September 10, 2024, 03:04:18 am »
 Hi I have two Fluke 189 meters, one meter it has 2.01 firmware, other it has 2.02, exist update software? like 289. Regards
Offline coromonadalix
Re: Fluke 189 firmware
« Reply #1 on: September 10, 2024, 11:53:58 am »
unless you clone some eeproms,  you wont find any updates for the 189  ... unless Fluke update them,  witch i would doubt
they are obsoletes
and doing so,  you may loose the calibration ...
let them be ... don't touch anything
Offline Fungus
« Reply #2 on: September 10, 2024, 02:23:16 pm »
Offline Njk
  • Country: ru
« Reply #3 on: September 10, 2024, 07:53:19 pm »
According to Fluke, "U16, mask ROM micro controller with 2k x 8 bytes RAM, Sharp SM6004, contains operating code for the product". That's why.
Offline BeBuLamar
« Reply #4 on: September 10, 2024, 10:34:06 pm »
How do you check the firmware version? I can't find it in the manual.
« Reply #5 on: September 10, 2024, 11:52:16 pm »
mmm was it when you power the meter with an pressed button ?   sorry  don't have theses anymore  ...  but i did saw something once
  • Country: mx
« Reply #6 on: September 11, 2024, 01:49:40 am »
Hi, I get the firmware version from fluke app
  • Country: mx
« Reply #7 on: September 11, 2024, 01:50:44 am »
Also you can see firmware version with Fluke viewforms software and Ir189USB cable, or with app with bluetooth adapter.
Offline BeBuLamar
« Reply #8 on: September 11, 2024, 02:17:27 am »
Thanks. My 189 is version 2.02. I got it around 2004 or so.
Offline armsom-jackson
  • Country: cn
« Reply #9 on: September 11, 2024, 02:51:31 am »
 :clap: :clap: :clap:
Where innovation on Arm SOM/SBCunites an open hardware/software community.
Online daisizhou
  • Country: cn
« Reply #10 on: September 11, 2024, 08:02:09 am »
Normally I wouldn't update the firmware because it's not an Apple phone.
Updating the firmware will only make things worse,In other words, even if the update does not improve any functions or performance
daisizhou#sina.com #=@
Offline Njk
  • Country: ru
« Reply #11 on: September 11, 2024, 03:10:35 pm »
Firmware version:
Push down the RANGE button and simultaneously turn the meter on.
Static display test:
Push down the HOLD button and turn the meter on.
Animated display test:
Push down the HOLD and BLUE buttons simultaneously and turn the meter on and wait a bit, must be hold down the buttons.
https://www.eevblog.com/forum/testgear/fluke-187
The following users thanked this post: Mickle T., coromonadalix
