Author Topic: Fluke 190 II Windows 10, Windows 11, x64 drivers  (Read 3446 times)
Offline patpatTopic starter
« on: November 02, 2024, 11:24:22 pm »
I recently got a 190-502 II and accessing the console or running any software on Windows 10 or 11
was not possible because drivers were only available for old Windows versions.
The Scope has an internal FTDI chip converting USB<->RS232.
The old XP/Win7 drivers originally provided by Fluke are just the FTDI drivers but using Fluke hardware identifiers:
VID_0F7E&PID_9006.DeviceDesc="Fluke USB Serial Port"
VID=0F7E
PID=9006
I took the modern x64 FTDI drivers, added Fluke IDs, rebuilt it, and it worked.
For installation just run "install_3.cmd" on an elevated prompt (for this just open a cmd instance as Admin)
For de-installation you can run FTDI CDMUninstallerGUI_v1.5.exe adding the corresponding Fluke identifier ( VID & PID ) from the ones mentioned before.
After driver installation and connecting the scope to the Windows 10/11 x64 PC you'll see the Fluke 190
in the Device Manger as shown below.
Edit 01:
Tested on Windows 11
  Firmware Upgrade -> OK
  FlukeView-1 version 5.4  -> OK
  FlukeView-2 for ScopeMeter® Test Tools version 3.2.0 64bit -> OK
« Last Edit: November 23, 2025, 07:14:56 pm by patpat »
The following users thanked this post: coromonadalix, brint.corb, alset
Re: Fluke 190 II Windows 10, Windows 11, x64 drivers
« Reply #1 on: February 21, 2025, 12:23:02 am »
I wonder why this page recently included in its HTML header
<meta name="robots" content="noindex"/>
Then is not indexed by Google...
Offline brint.corb
« Reply #2 on: November 10, 2025, 08:07:49 pm »
This worked for me thanks a lot!   Win 10,  fluke 190-104
