Author Topic: Fluke 190 II Windows 10, Windows 11, x64 drivers  (Read 450 times)
Offline patpatTopic starter
« on: November 02, 2024, 11:24:22 pm »
I recently got a 190-502 II and accessing the console or running any software from Windows 10 and 11
was not possible because drivers were only available for old Windows versions.
The Scope has an internal FTDI chip converting USB<->RS232.
The old XP/Win 7 drivers provided by Fluke are just the FTDI drivers but using Fluke hardware identifiers
VID_0F7E&PID_9006.DeviceDesc="Fluke USB Serial Port"
I took the modern x64 FTDI drivers, added Fluke IDs and it worked.
For installation just run "install_3.cmd" on an elevated prompt (for this just open a cmd instance as admin)
For de-installation you can run FTDI CDMUninstallerGUI_v1.5.exe adding the corresponding Fluke identifier ( VID & PID #s) from the one mentioned before.
After driver installation and connecting the scope to the Windows 10/11 x64 PC you'll see the Fluke 190
in the Device Manger as shown below.
Edit 01:
Tested on Windows 11
Firmware Upgrade -> OK
FlukeView-1 version 5.4  -> OK
FlukeView-2 for ScopeMeter® Test Tools version 3.2.0 64bit -> OK
« Last Edit: November 04, 2024, 01:00:21 am by patpat »
The following users thanked this post: coromonadalix, alset
