Author Topic: Fluke 289 firmware update question  (Read 7782 times)
Offline alank2Topic starter
« on: July 12, 2020, 04:48:45 pm »
I've got a pretty old Fluke 289 (calibration date 4/30/08) and it says its firmware is 1.10 / V0.88.  It also has a SN of 9673xxxx.
This doesn't make a lot of sense:
https://www.fluke.com/en-us/support/software-downloads/fluke-287-and-289-multimeter-firmware-update
They are talking about 42830001 shipping with firmware 1.41.
Then they mention : Owners of Fluke 289 multimeters with serial number 42830000 or LOWER can update to firmware version 1.16. These multimeters are NOT upgradable to any firmware higher than 1.16.
I don't even see a link for newer firmware, but part of me doubts my unit could handle it even though the SN is not lower than 42830000.
The following users thanked this post: Marco1971, Trader
Offline bdunham7
Re: Fluke 289 firmware update question
« Reply #1 on: July 12, 2020, 05:16:10 pm »
I've observed discontinuities in Fluke serial numbers on at least one other product, so you might want to ask Fluke directly and see if they can explain.  I'm not sure a firmware upgrade really gets you anything in this case.
Offline mqsaharan
  • Country: pk
« Reply #2 on: July 13, 2020, 01:27:06 pm »
It is always best to talk to the manufacturer.
As far as I know, your meter will support Firmware version 1.16 and not the newer 1.41. The newer firmware is for their newer board revision they did somewhere in mid/late 2018 and later ones.
Qasim.
« Last Edit: July 13, 2020, 02:48:05 pm by mqsaharan »
« Reply #3 on: July 13, 2020, 02:12:15 pm »
That is sort of what I was figuring too; thanks; I'll check with Fluke and see what they say.
« Reply #4 on: July 16, 2020, 12:37:40 pm »
Fluke says my serial number was from before it rolled over!  Upgrade to 1.16.
Offline Trader
« Reply #5 on: July 17, 2020, 02:17:08 pm »
Qasim, thank you, this info is useful for me, please, do you have the link to the source?
Offline oktay50000
« Reply #6 on: July 23, 2020, 04:52:24 am »
what is the difference between 1.41 vs 1.16 ??
did they answer you?
Offline texaspyro
« Reply #7 on: July 23, 2020, 06:10:03 am »
1.41 - 1.16 = 0.25   :-DD
The following users thanked this post: alank2
Offline coromonadalix
« Reply #8 on: July 23, 2020, 11:15:02 am »
 :palm:
« Reply #9 on: July 23, 2020, 12:01:35 pm »
They didn't, but I didn't ask.  The firmware update page link would suggest that they are different hardware versions and that is the reason.
Offline mqsaharan
  • Country: pk
« Reply #10 on: July 23, 2020, 03:02:57 pm »
Hi Trader, you are welcome. I'm sorry, I don't have any certified source. It is my own assumption.
I sent in my own 289 in Feb., 2018 and Fluke replaced the main board but with the same board ID 3. In Feb., 2019, I read a forum post by a member mr.fabe (https://www.eevblog.com/forum/testgear/fluke-189-with-leaking-surface-mount-coin-cell/msg2180516/#msg2180516) that he received his meter with a replaced main board from Fluke with a newer board revision bearing board ID 5 and 1.41 firmware. From that I conclude that Fluke did a new revision in mid/late 2018.
Qasim.
« Reply #11 on: July 23, 2020, 05:17:32 pm »
I think they had "the super capacitor problem too"
Offline dacman
« Reply #12 on: July 24, 2020, 10:05:40 pm »
I'm not quite sure what you're asking, but if you want the download links for Fluke Firmware, just google Fluke Firmware Update and click on any number of Fluke links.
