Author Topic: Fluke 289 to excel streaming  (Read 3047 times)
Offline UKpatTopic starter
« on: March 05, 2024, 10:24:36 pm »
Hi al
Was wondering if anyone here has managed to find a way of outputting the display info of a 289 to stream via usb to excel, hope this an acceptable question for this forum...regards Pat
Offline BeBuLamar
Re: Fluke 289 to excel streaming
« Reply #1 on: March 06, 2024, 04:57:32 pm »
The USB to Fluke 289 is a serial to USB converter so if you write a VBA module to communicate with the com port you can do that. Use the information in this file
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://www.uniteng.com/neildocs/facilities/Fluke289_remote_spec28X.pdf
I was able to read from the 289 by writing a program with Visual Basic. So VBA for Excel wouldn't be too much different.
Offline luma
« Reply #2 on: March 07, 2024, 11:52:56 am »
Sounds like an afternoon project with modern micros.  Take something like an ESP32-C3, feed a uart the serial stream, and have it run the USB port as an HID device to emulate the keystrokes.
Hell i’ll make the offer, send me a free 289 and I’ll have you a solution in a day :)
Offline BeBuLamar
« Reply #3 on: March 07, 2024, 12:23:49 pm »
There are pre made software (from Fluke and others) to records readings to a *.csv file which can be opened in Excel. Unless you have reasons that need the data to go into Excel directly those are easy solution.
