Products => Test Equipment => Topic started by: jonsig on May 13, 2015, 09:22:34 pm
Hi i got this beast .
I´m wondering if its broken because the only way for me to use the touch hold feature is to select ohms , volts_dc etc. And
hold the yellow select button in for few seconds before it finishes booting up :scared: .
And when its in touch hold mode the only way to turn it off is to reset the meter , turn it to off position .
(http://i77.photobucket.com/albums/j47/nonni2000/11109261_10153205458728213_1721584058591480177_n_zpsce0bpc3x.jpg) (http://s77.photobucket.com/user/nonni2000/media/11109261_10153205458728213_1721584058591480177_n_zpsce0bpc3x.jpg.html)
Working as per manual.
Thank you , i have only found service manuals so far .
An user manual is here.
https://www.cs.washington.edu/1999/lab/facilities/hwlab/docs/mans/77______umeng0200.pdf (https://www.cs.washington.edu/1999/lab/facilities/hwlab/docs/mans/77______umeng0200.pdf)
