Author Topic: Looking for compact insulation tester  (Read 2106 times)
Offline 001Topic starter
  • Country: aq
« on: October 31, 2017, 03:36:21 pm »
I`m looking for compact insulation tester to check DIY transformer isolation with 1kV DCV (1.5kV will be awesome)
Since it is only insulation, acurasy of +/-25% will be ok  :palm:
Can I find some afordable toy at ebay/ali? (is it usable? https://www.ebay.com/itm/HDT20A-LCD-Digital-Insulation-Resistance-Tester-Megohmmeter-Meter-1000V-Hot/361857687789?epid=16004017841&hash=item54406620ed:g:ki8AAOSwa~BYV5T2 )
May be somebody made some DIY wariant of insulation tester? Help with the schematic please
Thanx!
« Last Edit: October 31, 2017, 03:45:27 pm by 001 »
Offline Mr. Scram
  • Display aficionado
Re: Looking for compact insulation tester
« Reply #1 on: October 31, 2017, 04:08:50 pm »
Thanx!
What did your research turn up? It seems you're starting a lot of "what to buy" threads, but there is a lot of great information out there. It would help if you could post the things you've looked at and why you liked some, and didn't like others.
  • Country: aq
« Reply #2 on: October 31, 2017, 04:15:46 pm »
NOT TURN. BUT INSULATION of my self made transformers
Now I use this muscul-powered monster  :palm:
« Last Edit: October 31, 2017, 04:18:16 pm by 001 »
Offline Electro Detective
« Reply #3 on: November 01, 2017, 09:44:17 pm »
If you prefer or are used to the analogue meter style, the KYORITSU 3132A or a rebadged model like Sperry etc  is a nice insulation tester that supplies 250V/500V/1000+ Volts of DC juice,
has Ohms/Continuity test and a voltage alert in case the DUT is energized.
It takes 6 AA batteries, compact with a protective cover, and easy to use with no menus or multifunction digital wankery to think about when you're busy  |O
The TEST button can be pressed when needed, or pressed and turned for continuous insulation 'zap'   :o    with auto discharge  :phew:
They are common and well priced if used, and easy to test with any multimeter if they are ok or not,
just check for battery leakage if buying used.
Bear in mind that you have to half or double what the meter reads at 250v and 1000v positions, because the 3132A meter needle calibration is set for the 500v standard,
whereas a digital tester gives a direct readout = no big deal or major math work   ;D
Keep your windup one too, because it works without batteries   :clap:
There are some decent cheap digital insulation testers too, get one with DAR and PI functions if affordable
If you do a lot of insulation testing, or for peace of mind, it's handy to have an analogue, digital, and a manual windup tester to double check and verify your work  :-+
The following users thanked this post: 001
  • Country: aq
« Reply #4 on: November 02, 2017, 01:20:48 pm »
It is intersting  :-+
Can You help me with some nowday meggers service manuals or schematics?
