Author Topic: Fluke 83V vs 87V - Spot The Differences!  (Read 5833 times)
Offline gamalotTopic starter
  • Correct my English
    • Youtube
« on: December 15, 2022, 02:18:52 am »
I found three obvious differences, can you find more?  :-DMM
This image of the Fluke 87V below is from a post by forum member @SerjP: https://www.eevblog.com/forum/testgear/fluke-87v-(2021)-teardown/
« Last Edit: December 15, 2022, 02:29:20 am by gamalot »
I'm a poet, I didn't even know it. |  https://youtube.com/@gamalot | https://github.com/gamalot
Re: Fluke 83V vs 87V - Spot The Differences!
« Reply #1 on: December 15, 2022, 02:22:30 am »
Labels are different !  :P
The following users thanked this post: gamalot
Offline timenutgoblin
« Reply #2 on: December 15, 2022, 05:16:08 am »
Not sure if it's obvious because I didn't see it immediately.
Both PCBs have a hybrid resistor network located below an LT/Fluke IC and further below, along the bottom of the PCB, there are four components as can be seen in the top photo. However, the two grey coloured capacitors are omitted in the bottom photo.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: December 15, 2022, 05:37:48 am »
i remember i won a spot the difference contest and brought a KFC bucket home as a prize...
« Last Edit: December 15, 2022, 05:40:25 am by Mechatrommer »
Offline coromonadalix
« Reply #4 on: December 15, 2022, 11:25:09 am »
And the question would be
Can we convert an 83 into an 87 ??  is the firmware extractable ?
Offline Arhigos
  • Country: gr
« Reply #5 on: December 15, 2022, 01:35:37 pm »
83v Missing transistor under 440mA fuse  8) (not visible on pictures)
« Reply #6 on: December 15, 2022, 06:47:37 pm »
There are a few parts you can't see that are missing from the 83, mostly to do with the LPF and the MUX it switches through, afaik. Other than that it uses the same parts, including the same A grade of LT1790-2.5, which does make me wonder what accounts for the specified difference in performance in the non-AC ranges. More careful calibration and adjustment at the factory?
The Hi-Res mode on the 87 is sw rather than hw, as evidenced by the bug in the lower current ranges.
As long as the MCU is reprogrammable I guess you could just load an 87 fw, add the parts, and have an 87V.
    • Youtube
« Reply #7 on: December 16, 2022, 01:12:25 am »
Although the user manual only gives 83V AC performance below 5KHz, it works fine at 20KHz in the tests I've done.
Getting 87V firmware should be mission impossible, trying to save money by buying an 83V and converting it to 87V is a waste of life, except for fun.  :popcorn:
  • Country: my
« Reply #8 on: December 16, 2022, 05:59:42 am »
not impossible, unless what you meant is Tom Cruise style mission impossible movie. such as wait for a broken 87V in ebay and remove the chip to 83V. waste of money as well since calibration is a part of money you paid, and doing the mod is risking screwing or redoing the calibration. btw, another spot the difference spotted... no white mark on the knob for 83V! someone mourned about that recently, i'm going to forward the picture there. https://www.eevblog.com/forum/testgear/fluke-87v-switchs-white-mark/?topicscreen
« Last Edit: December 16, 2022, 06:03:12 am by Mechatrommer »
« Reply #9 on: December 16, 2022, 06:11:53 am »
It is possible to recalibrate, but I'd also agree there seems little point other than as a challenge, just much easier to get an actual 87V.
  • Country: my
« Reply #10 on: December 16, 2022, 06:47:22 am »
surprisingly last night i checked in ebay US, you can get cheaper 87V than 83V... grey market or not is another story.
Offline Arhigos
  • Country: gr
« Reply #11 on: December 17, 2022, 02:02:35 am »
Technically you can add true rms feature just by soldering missing components
    • Youtube
« Reply #12 on: December 17, 2022, 04:56:14 am »
Yeah ... nah, I saw this video when it was just released, fun to try but not worth it, especially when you have too many multimeters, you're happy to have an average meter instead of RMS like the rest.  :-DMM
Offline tooki
« Reply #13 on: December 17, 2022, 02:16:36 pm »
While the list price of the 83V is slightly lower, my guess is that the volume sold of the 83V is tiny compared to the 87V, such that dealers are able to negotiate far better volume discounts on the 87V, explaining why some dealers charge the same for both, sometimes even more for the 83V!
It also maybe means that far more 87V units are available on the used market, pushing down the price a bit.
The following users thanked this post: Fraser
Offline tooki
« Reply #14 on: December 17, 2022, 02:19:49 pm »
Both the 83V and 87V originally had the paint line, now they both don’t.
Offline BeBuLamar
« Reply #15 on: December 18, 2022, 02:30:10 pm »
Fluke keeps the 83V in production (they don't have the 85V) not for people who doesn't want to pay the price of the 87V but for people who don't want true RMS. Fluke priced them about the same price. So it makes no sense trying to make the 83V to be the 87V.
Offline Fungus
« Reply #16 on: December 18, 2022, 03:24:04 pm »
AFAIK the 83V is also lacking the hi-res mode and is less accurate.
Most users probably don't care though, 6000 counts and 0.1% is plenty accurate for most jobs.
Offline BeBuLamar
« Reply #17 on: December 18, 2022, 05:00:01 pm »
Mainly if you buy the 83V it's because you want everaging meter not so much on saving money. To save money you would go to the 17x series.
Offline Fungus
« Reply #18 on: December 18, 2022, 06:20:19 pm »
I'm sure there's many written test procedures and manuals out there that rely on using averaging meters.
Offline andyB2022
« Reply #19 on: February 22, 2023, 07:32:13 pm »
As I see from your picture, the rotary knob of the meter does not have the little arrow painted in white. Is this common? I've seen another meter these days and I've thought it might be a knock off.
    • Youtube
« Reply #20 on: February 22, 2023, 08:27:21 pm »
This is normal, IIRC there is another thread discussing it.
Offline andyB2022
« Reply #21 on: February 22, 2023, 08:30:56 pm »
I'm sorry, what does IIRC mean? Do you have a link to that thread?
    • Youtube
« Reply #22 on: February 22, 2023, 08:51:02 pm »
IIRC = if I recall correctly
