Author Topic: Fluke 87-IV replacement front plastic screen  (Read 1110 times)
Offline masterx81Topic starter
« on: February 22, 2020, 05:19:10 pm »
Hi! Someone know where to find a front screen (or the whole front cover) for an 87-4? I've bought it as failed as had the corroded contacts (aliexpress had them cheap) and for some missing segments on the display. Fixed the segments problem only with a good clean of contacts and zebra strips, but the previous owner, when the display wasn't working, had pushed hard the plastic protection screen, cracking it.
The other parts of the device are almost perfect, not much use, very accurate (more than my lb02 process calibrator 😅). It allow some rest to my old protek 506...
Thanks!
Re: Fluke 87-IV replacement front plastic screen
« Reply #1 on: February 22, 2020, 10:50:27 pm »
Need to find a 3mm acrilic sheet and a cnc...
« Reply #2 on: February 23, 2020, 11:26:53 am »
Actually, the oem plastic screen isn't simply glued to the case, seem that the case was molten around it. So the removal process insn't easy as it sound. After the removal  there isn't any plastic to glue the new screen, remain only the glue that can be put on the sides (and not do much on the resistance). I'll try to do it anyway, so that i can use it until i find a replacement.
So, now i'm searching the whole front cover. Someone know where find it?
Thanks!
