Author Topic: Fluke 87V causes cancer!  (Read 19482 times)
Offline FungusTopic starter
Re: Fluke 87V causes cancer!
« Reply #75 on: August 28, 2017, 05:08:17 pm »
When is the title going to be to changed to: "Fluke 87V can cause cancer"?  :palm:
If the sample size was 'one' you'd be correct, but is isn't.
In any statistically significant group of engineers a Fluke 87 will cause cancer.
Offline The Soulman
  • The sky is the limit!
« Reply #76 on: August 28, 2017, 05:56:06 pm »
Still a far fetch but ok.
"Will cause" is something different than "causes" tho.
Offline ConKbot
« Reply #77 on: August 28, 2017, 11:05:59 pm »
You probably shouldnt handle the manual either, as it's printed on paper and Caffeic acid is on the list.
Caffeic acid is an organic compound that is classified as a hydroxycinnamic acid. ... It is found in all plants because it is a key intermediate in the biosynthesis of lignin, one of the principal components of plant biomass and its residues.
The following users thanked this post: Electro Detective
Offline Electro Detective
« Reply #78 on: August 29, 2017, 06:00:59 am »
There are other risk issues with the Fluke 87V to beware of, before any slow onset of cancer or VD, roids, scrotum rash etc  kicks in    >:D
Accidental Self Strangulation with the leads
Stabbing oneself with the probes and bleeding profusely
Lung damage and nostril burn from yellow holster sniffing
Update Edit:
Foot injury from such a heavy meter drop, and or long term incapacitation from nerve and bone damage
Sterility in the event the meter falls and swings hard into one's private parts, whilst holding the probes tightly to save the 'expensive meter' from the awaiting concrete peril below
Any of the factors above may contribute to unemployment and a bad day in the sack
worst case the destitute owner resorts to crime, using the probes as weap0ns to threaten greedy evil rich people, the leads to tie up h0stages etc
...or if the p0lice and Sw@t rock up, claim the meter is a b0mb and will go 0ff on the third BEEP if/when probes get shorted, once the device gets selected to the deadly  [ __ \$\Omega\$__ ]   or DIE->ODE   position.
(FYI to dummies: that's the only way you might have a slim hope to bail out of there, after requesting a helicoptor, bikini clad female pilot, bag of unmarked cash, tub of KFC and coke..)
At least my 87Vs measure right every time, otherwise I would Ebay the suckers
and drag out the AVOmeter, and safely prod away... wearing a full nuke suit and breathing gear   :phew:
« Last Edit: September 02, 2017, 05:36:57 am by Electro Detective »
The following users thanked this post: CatalinaWOW
