Author Topic: Newly acquired signal generator ET3360C disassembly test  (Read 1325 times)
Offline clementTopic starter
  • Country: sg
« on: July 06, 2023, 08:08:46 am »
I received the signal generator today. Unlike other white shells, it has a black appearance. The shell is made of plastic material, and the product is very light, and the waveform is not particularly good. So I took it apart and found that there are many relays on the circuit board, and there are two unknown connecting wires. It feels like a repaired product, which completely does not meet my expectations.
Online Aldo22
Re: Newly acquired signal generator ET3360C disassembly test
« Reply #1 on: July 06, 2023, 10:17:33 am »
The soldered wires seem to be normal.
Someone posted a photo of the same board on Banggood.
The sine wave looks weird.
Can the oscilloscope keep up? Amplitude modulation?
« Last Edit: July 06, 2023, 10:44:46 am by Aldo22 »
  • Country: sg
« Reply #2 on: July 08, 2023, 03:26:59 am »
Using "Keysight Technologies" Bandwidth 1G,There will be relatively high peaks in the test sine wave output, I am worried that it will burn out my equipment, and I am ready to return it
Online coromonadalix
« Reply #4 on: February 18, 2024, 07:25:36 am »
Return this ....
