I have two ARINC429 analysers - old ex Ebay stuff from MAXT. One is PCMCIA in a winXP laptop, and the other is a PCI card in my PC (which is much more solid). These have loads of features; I can load e.g. an AHRS decode package and have the the labels all decoded. And generate all kinds of simulation data. I wasn't expecting that level of support on a scope. Just a display of the 1s and 0s in the 32-bit packet. I've written a load of ARINC429 code, using a HI3593.
I was keen to see if this scope can be made to do decoding. It may just be handy one day, but probably not since the UI on these scopes is only just usable on "normal" signals (the touch screen is completely useless, so I use a trackball) and IME the main benefit of a DSO is the storage aspect of it. It can of course display the data (see screenshot below) but that is as far as I can get - no analysis.
ARINC429 doesn't appear under the trigger options, which include all sorts like CAN STD etc. But that would be complicated; you really need the huge library of label formats to trigger on values, because the values vary per label. And there are many cases of the same label having different meanings.
I also wondered if the Decode 2 option (my last post above) might work, since it has no clock/cs options, just data. But no luck with that.
Probably the problem is that I have no info on how to use any of these features. For example what does Configure Table do?
