Author Topic: Tiny little Uni-T function generator  (Read 3620 times)
Online FungusTopic starter
« on: December 07, 2020, 05:52:53 pm »
Just saw this new 2-channel arbgen from Unit-T. Very tiny and cute... and only 80-odd Euros! (less than 100$?)
https://www.aliexpress.com/wholesale?SearchText=UTG962E+
Re: Tiny little Uni-T function generator
« Reply #1 on: December 07, 2020, 05:54:29 pm »
Here's a video comparing it to a much more expensive Siglent, it does better!
The following users thanked this post: werediver
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #3 on: December 07, 2020, 06:14:51 pm »
Hah! OK, I hadn't seen that thread.
Offline tautech
« Reply #4 on: December 07, 2020, 07:45:54 pm »
:blah:  :blah:
Oh FFS they guy's a muppet comparing 10yr old models to latest releases.  ::)
Then he couldn't even state the correct model # and its max frequency yet it's right in front of him in the units labelling.  :wtf:  :bullshit:
Online coppice
« Reply #5 on: December 07, 2020, 07:57:36 pm »
:blah:  :blah:
What difference does it make that the Siglent models are 10 years old? The SDG810 and SDG1062X are still Siglent's current offerings.
Offline tautech
« Reply #6 on: December 07, 2020, 08:02:02 pm »
:blah:  :blah:
SDG1052 SDG810 is what he was using. It's an old outdated model despite still being produced.
Doesn't hold a candle to the full capabilities of any of the later X models.
« Last Edit: December 07, 2020, 08:16:26 pm by tautech »
Online coppice
« Reply #7 on: December 07, 2020, 08:08:35 pm »
:blah:  :blah:
SDG1052 is what he was using. It's an old outdated model despite still being produced.
The one he uses is an SDG810. He has the SDG1062 (I didn't notice the lack of an X before) on his white board comparison. The SDG810 is still a current model.
Offline alextwin007
  • Collector of mini test equipment
« Reply #8 on: December 07, 2020, 08:17:09 pm »
Yeah as mentioned above check out the full thread on this.  I have one and I'm very pleased with it but I don't use the AWG functionality, but it seams like the AWG function isn't the best, with the software being bad, and the fact that it loses the waveform when powered down.
Having a test equipment addiction is difficult when you don't have a lot of room.  The solution, only collect small adorable test equipment.
Looking for a tek 1401 / 1401A, if you have one message me
Offline bc888
« Reply #9 on: December 08, 2020, 01:04:52 am »
:blah:  :blah:
Please forward to 12:10 in James Hetfields video. Nuff said?
Offline masterx81
« Reply #10 on: December 08, 2020, 09:20:16 am »
I really not like the 20ns rise time... on the other side, for example, the psg9080 have an r-2r dac that i would non consider. And i wouldn't bet also on the fy6900 (as i have one, full modded). Every of this devices have it's shortcomings, seem that it's impossible to do a good and cheap device...
  • Country: my
« Reply #11 on: December 08, 2020, 09:37:35 am »
external circuit consisting high speed comparator or jelly bean transistors is very easy to assemble if you want fast rise time. otoh good user experience in using the FG cannot be replaced with anything else other than what already provided out of factory, without modding it extensively, even require FW changes etc, in short building our own FG from scratch ;)
« Reply #12 on: December 08, 2020, 10:17:44 am »
It's not a pulse generator.  :-//
If you hate that then you really wouldn't like the steppy sine waves if it didn't have a low-pass filter on the DAC output...
« Last Edit: December 08, 2020, 10:26:48 am by Fungus »
« Reply #13 on: December 08, 2020, 10:21:51 am »
:blah:  :blah:
Somebody said something bad about a Siglent, expect a bit of vitriol.
Offline masterx81
« Reply #14 on: December 08, 2020, 11:27:35 pm »
On the fy6900 (4ns rise time) on 5vpp sine i start to see the steps under 5khz. I think that on the utg will be much lower.
I love have only one device to do things 😅
« Last Edit: December 09, 2020, 07:56:02 am by masterx81 »
  • Country: my
« Reply #15 on: December 08, 2020, 11:52:48 pm »
if you follow the other thread. the synch output to synch sweep signal is 1ns rise time iirc... so if we need some TDR toy, we already have one ready...
edit: here... 900+ ps
from https://www.eevblog.com/forum/testgear/uni-t-utg932utg962-200msas-function-arbitrary-waveform-generator-220394/msg2927402/#msg2927402
« Last Edit: December 08, 2020, 11:55:36 pm by Mechatrommer »
The following users thanked this post: Fungus
