Author Topic: Fluke clone?  (Read 9240 times)
Offline AxtmanTopic starter
Fluke clone?
« on: March 21, 2014, 05:08:30 pm »
This multimeter looks just like a Fluke 85V but probably is not.  Does anybody recognize the brand?
Offline SoundTech-LG
Re: Fluke clone?
« Reply #1 on: March 21, 2014, 05:14:18 pm »
I don't see any brand at all...
Re: Fluke clone?
« Reply #2 on: March 21, 2014, 05:21:43 pm »
SoundTech-LG,
You are correct.  There is no brand.  I am asking if anybody recognizes this as a counterfeit or clone.
Re: Fluke clone?
« Reply #3 on: March 21, 2014, 05:24:09 pm »
Where did you get that photo???
Offline retiredcaps
Re: Fluke clone?
« Reply #4 on: March 21, 2014, 05:36:05 pm »
There is no such thing has a 85V.  There is an original 85 and 85 III.  Fluke never made a 85V.
From the pictures, that is a real Fluke original 87.  You can tell from the slanted font and the peak min/max feature silk screen.  Additionally, the original 83 and 85 never had a yellow backlight button.
Re: Fluke clone?
« Reply #5 on: March 21, 2014, 05:51:37 pm »
Sorry my mistake.  I meant 87V.
This photo is from an ad on Craigslist.  The guy originally said it was a Fluke look alike.  I emailed him and asked that he remove the yellow cover and check the back.  He emailed back and said it was labelled "Fluke".  I am suspicious since I have never seen a true Fluke multimeter that was not permanently marked "FLUKE".
Offline retiredcaps
Re: Fluke clone?
« Reply #6 on: March 21, 2014, 05:54:57 pm »
Are you serious? If you're going to correct someone you should check your facts first.
It's not like the 85V is a new model. Maybe I just missed the joke - if so I apologize...
Fluke's current series V models are the 83V and 87V.  They have never made a 85V.
Straight from the vendor ...
http://www.fluke.com/fluke/caen/digital-multimeters/fluke-80-series-v.htm?PID=56135
Offline rstoer
Re: Fluke clone?
« Reply #7 on: March 21, 2014, 05:58:33 pm »
My mistake. Brain was out to lunch....
Offline retiredcaps
Re: Fluke clone?
« Reply #8 on: March 21, 2014, 05:59:36 pm »
There is no way that meter in the picture you provided is a 87V.  It is an original 87 series (I).
Have a look at modemhead's 87 generation collection photo at
www.eevblog.com/forum/chat/show-your-multimeter!/msg333457/#msg333457
The leftmost 87 is an original series I, but with an upgraded lcd.  The 3 Fluke 87s on the right are the I, III, and V respectively.
« Last Edit: March 21, 2014, 06:05:52 pm by retiredcaps »
Offline retiredcaps
Re: Fluke clone?
« Reply #9 on: March 21, 2014, 06:01:06 pm »
No worries.  :-+
Offline retiredcaps
Re: Fluke clone?
« Reply #10 on: March 21, 2014, 06:11:44 pm »
At the $155 USD asking price, I would pass.  With patience, you can easily get a  working Fluke 87 I on ebay for $100 USD or less.
http://seattle.craigslist.org/see/eld/4384837134.html
If you can get the Fluke 189 for $150 USD, I would go for it.
Offline Excavatoree
Re: Fluke clone?
« Reply #11 on: March 21, 2014, 06:43:10 pm »
Because the secondary functions are blue and not yellow, the front case is not from an 83-V or an 87-V.   I'm guessing it's an 87
If I remember correctly, the 87-V has the labeled surround, so the only way it could be an 87-V is if someone changed the LCD surround and front case.  (windows are welded to the front case.  and aren't eaisily replaced.)
The button assy is from an original 87 or a cat II 87.  (It doesn't have the "sun" on the backlight button that the -III has)
My guess it's an 87 I or II (none were labeled II, that's just the second, category rated version)  with a different front case on it.  The blank LCD surround is intended for use with a printed window, while a blank windowed front case was intended to be used with a labeled surround.  In any case, the LCD surround and case don't match. on this meter.
I'd say it's a genuine Fluke SOMETHING, but since parts have been mixed and matched, anything's possible.  My guess is simply the most probable.
EDIT: That's what I get for not reading ALL the replies first.  I see RC came to the same conclusion.  (I agree with his recommendation about buying)
« Last Edit: March 21, 2014, 06:53:38 pm by Excavatoree »
