This is everything I managed to retrieve. The non working PM95 does not respond to flukesavecal.exe, it comes back with "bad acknowledge from instrument, aborting". However it does respond to flukev4dump.exe. (see attached).
Next job is to erase the 95, reload the flash.bin back in and see if it's there. If so then flukev4flash.exe works.
Is there a method then to compare the two flash.bin files and see if they match ? If so then I still do not have a working device
but it will prove that you can erase and write back with Marrob's software.
