Author Topic: Fluke fuse  (Read 1351 times)
Offline Liteace
Fluke fuse
« on: March 29, 2017, 10:31:23 pm »
Ive got here an like new old Fluke 23 series 2, the large fuse has popped inside, i only use this tester for automotive testing, volts, amps & residence.
I cant get a new fuse locally and will have to order it,  it wouldn't make any difference if i put a normal 20 amp fuse in would it?
Thanks
Offline retiredcaps
Re: Fluke fuse
« Reply #1 on: March 29, 2017, 10:35:40 pm »
No, don't put in a bigger rated fuse. Use the proper rated fuse and specifications for your meter.
Offline ModemHead
  • No user-serviceable parts inside.
    • Mr. ModemHead
Re: Fluke fuse
« Reply #2 on: March 30, 2017, 12:01:10 am »
Yes, stick with the proper fuse.  But when you search for a replacement, look for KTK-15 (Bussmann), KLK-15 (Littelfuse), and Fluke 820829.  It may expand your options.
Offline james_s
Re: Fluke fuse
« Reply #3 on: March 30, 2017, 12:01:51 am »
You can't guarantee that you or someone else will never use the meter on mains voltage or higher. These fuses are special for a very specific reason, and should never be substituted with a cheap ordinary fuse.
