Author Topic: FNB58 app  (Read 11037 times)
Online PlainNameTopic starter
  • Country: va
FNB58 app
« on: January 06, 2024, 01:46:04 pm »
Acquired a FNIRSI FNB58 USB meter and made sure it was the BT version so I can connect via my phone. But now I wonder what the point of Bluetooth is on this because I can't find the app anywhere. A google search turns up some info, mostly a reddit thread about it not working on Android 14, but no actual app.
Anyone know if it really exists and, presuming it does, where to get it?
Online csuhi17
  • Country: hu
« Last Edit: January 06, 2024, 02:14:33 pm by csuhi17 »
Fnirsi oscilloscope = waste&regret
  • Country: va
Re: FNB58 app
« Reply #2 on: January 06, 2024, 02:18:10 pm »
Yes, I can find references that the apk is on the website, but I can't find it on the website. Got the PC application, etc, but no apk.
Online csuhi17
  • Country: hu
Re: FNB58 app
« Reply #3 on: January 06, 2024, 02:32:14 pm »
[ Specified attachment is not available ]
Mine connects to the phone, but I haven't been able to extract data with it yet.
first press "Run" in the upper right corner, then "Run" in the red circle in the middle...
« Last Edit: January 06, 2024, 02:42:59 pm by csuhi17 »
Offline Jon.C
  • Country: ad
Re: FNB58 app
« Reply #4 on: January 06, 2024, 02:34:47 pm »
  • Country: va
Re: FNB58 app
« Reply #5 on: January 06, 2024, 09:42:05 pm »
Thanks very much, both. For some reason the website I see is not like the one in the screenie, but knowing it is there lent me the perseverance to figure out how to get there in the end  :-+
Offline Martini
Re: FNB58 app
« Reply #6 on: June 20, 2024, 01:52:03 pm »
Here's the link to the Bluetooth app for future reference: https://www.mediafire.com/file/if2gm8oiv99xasx/FNIRSI_Bluetooth_APP__old%25EF%25BC%2588Android%25EF%25BC%2589_v1.0.apk/file
I know it looks shady but it's how FNIRSI do it.
On their download firmware page (https://www.fnirsi.com/pages/download-firmware), under USB tester, you'll find a *.txt file with two links: one to the PC app and one to the Android app.
If you want to update the firmware, it's of course (!!) not available on the /download-firmware page but rather on the FNB58 product's page:
https://www.fnirsi.com/collections/usb-tester/products/fnb58
But to update the firmware, you'll need the PC software from the /download-firmware :palm:
The procedure is on page 17 of the manual (https://www.fnirsi.com/cdn/shop/files/FNB58-_Manual.pdf?v=15001951769436062594)
The following users thanked this post: PlainName
Offline mjhughes
    • Boondock Echo
I hacked the FNB58
« Reply #7 on: November 04, 2024, 08:32:09 pm »
The FNIRSI app for Android sucks hard.  I tried decompiling it, and it's a hot mess.  Something like 750000 lines of code scattered across 50000 files. |O  In other words -- a big fact mess.
Instead, I intercepted the ble packets and deduced their meaning.
There are links to the python code I wrote in the github (see video description).  It's only for Voltage and current because that's all I needed for Power.  But deducing the other datatypes shouldn't be hard with a few controlled tests on the workbench and packet capture.  (Details of how to proceed provided in an article at https://www.boondockecho.com/news/hacking-bluetooth-to-learn-more-about-boondock-battery-life and in the video).  The structure is laid out in the file
In short -- the code there let's you get voltage and current over bluetooth le now (using python).  If you want other info like DP and DN voltage, temperature, etc., it'll be a couple more hours work.
Good luck!
