#include "fpga_control.h"
void fpga_init(void)
  //First set pin high in data register to avoid spikes when changing from input to output
  FPGA_CLK_INIT();
  //Initialize the three control lines for output
  FPGA_CTRL_INIT();
void fpga_write_cmd(unsigned char command)
  //Set the control lines for writing a command
  FPGA_CMD_WRITE();
  //Set the bus for writing
  FPGA_BUS_DIR_OUT();
  //Write the data to the bus
  FPGA_SET_DATA(command);
  //Clock the data into the FPGA
  FPGA_PULSE_CLK();
unsigned char fpga_read_cmd(void)
  //Set the bus for reading
  FPGA_BUS_DIR_IN();
  //Set the control lines for reading a command
  FPGA_CMD_READ();
  //Clock the data to the output of the FPGA
  FPGA_PULSE_CLK();
  //Read the data
  return(FPGA_GET_DATA());
void fpga_write_byte(unsigned char data)
  FPGA_DATA_WRITE();
  FPGA_BUS_DIR_OUT();
  FPGA_SET_DATA(data);
  FPGA_PULSE_CLK();
unsigned char fpga_read_byte(void)
  FPGA_BUS_DIR_IN();
  FPGA_DATA_READ();
  FPGA_PULSE_CLK();
  //Read the data
void fpga_write_short(unsigned short data)
  FPGA_DATA_WRITE();
  FPGA_BUS_DIR_OUT();
  //Write the msb to the bus
  FPGA_SET_DATA(data >> 8);
  FPGA_PULSE_CLK();
  //Write the lsb to the bus
  FPGA_PULSE_CLK();
unsigned short fpga_read_short(void)
  unsigned short data;
  FPGA_BUS_DIR_IN();
  FPGA_DATA_READ();
  FPGA_PULSE_CLK();
  //Get the msb
  data = FPGA_GET_DATA() << 8;
  FPGA_PULSE_CLK();
  //Get the lsb
  data |= FPGA_GET_DATA();
  //Read the data
  return(data);
