sudo dd if=fel-sdboot.sunxi.txt of=/dev/sdc bs=1024 seek=8
Hi, new here. I was looking for info about this oscilloscope which I plan to buy for checking stuff around the house (utility power, UPS, and portable generator outputs, etc.)
Why I gess there is a problem with the TP (maybe just configuration) is because touching the panel send no I2C signals at all to the 100S.
Since the lines always seem to be high it can also be that they are shorted to VCC, causing larger currents to flow when the F1C100s makes these lines low. This could explain the high temperature of it.
It was not easy with older eyes and not as steady in the hand anymore as time has gone by rather quickly. One moment you are in your forties and then you are almost sixty.
Hi everyone I'm a newbie I have a 2013d but the screen is cracked not the front glass it doesn't work at all does anyone know of a screen I can replace it with the makers do not want to know at all ⁴
frame bit tilename type x y
0 826 mic_lr_x0y22 miscs_mic_io_l 0 22
0 828 mic_lr_x0y22 miscs_mic_io_l 0 22
0 829 mic_lr_x0y22 miscs_mic_io_l 0 22
0 880 mic_lr_x0y22 miscs_mic_io_l 0 22
0 882 mic_lr_x0y22 miscs_mic_io_l 0 22
0 883 mic_lr_x0y22 miscs_mic_io_l 0 22
0 904 mic_lr_x0y22 miscs_mic_io_l 0 22
0 906 mic_lr_x0y22 miscs_mic_io_l 0 22
0 907 mic_lr_x0y22 miscs_mic_io_l 0 22
0 923 mic_lr_x0y22 miscs_mic_io_l 0 22
0 958 mic_lr_x0y22 miscs_mic_io_l 0 22
0 960 mic_lr_x0y22 miscs_mic_io_l 0 22
0 961 mic_lr_x0y22 miscs_mic_io_l 0 22
1 914 mic_lr_x0y22 miscs_mic_io_l 0 22
1 921 mic_lr_x0y22 miscs_mic_io_l 0 22
1 932 mic_lr_x0y22 miscs_mic_io_l 0 22
2 940 x0y20 pib 0 20
3 619 x0y26 pib 0 26
4 621 x0y26 pib 0 26
5 942 x0y20 pib 0 20
24 975 x0y19 pib 0 19
27 975 x0y19 pib 0 19
156 620 x5y26 plb 5 26
158 620 x5y26 plb 5 26
246 616 x8y26 pib 8 26
249 297 x8y32 pib 8 32
250 295 x8y32 pib 8 32
250 617 x8y26 pib 8 26
433 285 x14y32 plb 14 32
435 284 x14y32 plb 14 32
617 297 x20y32 plb 20 32
619 296 x20y32 plb 20 32
801 292 x26y32 plb 26 32
802 294 x26y32 plb 26 32
811 27 x26y37 pib 26 37
813 26 x26y37 pib 26 37
880 22 x28y37 pib 28 37
882 23 x28y37 pib 28 37
882 57 x28y36 plb 28 36
885 57 x28y36 plb 28 36
887 11 mic_tb_x28y37 miscs_mic_io_t 28 37
887 21 mic_tb_x28y37 miscs_mic_io_t 28 37
887 23 mic_tb_x28y37 miscs_mic_io_t 28 37
888 13 mic_tb_x28y37 miscs_mic_io_t 28 37
888 20 mic_tb_x28y37 miscs_mic_io_t 28 37
888 22 mic_tb_x28y37 miscs_mic_io_t 28 37
890 8 mic_tb_x28y37 miscs_mic_io_t 28 37
890 21 mic_tb_x28y37 miscs_mic_io_t 28 37
890 23 mic_tb_x28y37 miscs_mic_io_t 28 37
918 14 mic_tb_x29y37 miscs_mic_io_t 29 37
918 16 mic_tb_x29y37 miscs_mic_io_t 29 37
918 23 mic_tb_x29y37 miscs_mic_io_t 29 37
919 18 mic_tb_x29y37 miscs_mic_io_t 29 37
919 20 mic_tb_x29y37 miscs_mic_io_t 29 37
919 22 mic_tb_x29y37 miscs_mic_io_t 29 37
o56v~ 3 0
CcD 4 25 qPn"QxyGnwTr}5E.6 1 r|c\tR3qHSxT 2 r|c\tR3qPdeD 3 r|c\tR3rPT5CutIa 4 tN3}E_5D}ucVtVvd 5 E[5Or#cQ"G3|Ycg 6 C}2QP&as|In"W(e 7 E[5Or#cQ"G3|Yci 8 C}2QP&as|In"W(g 9 E[5Or#cQ"G3}Y[*3i+5G 10 tN3}E_5D}uc\+N(i\H 11 tN3}E_5D}uc\+Ze 12 qPn#C$2JF#W, 13 qPn#C$2JG#W, 14 qPn#C$2KP*Ge 15 qPn#C$2P[#W, 16 qPn#C$2Pd*3 17 r|c\tR3|Yce 18 C}2QP&a}(XB 19 tN3}E_5N)'8 20 P"a~qTn"W(e 21 E[5Or#c[+Vg 22 qPn#C$2Qd"V3qHS 23 tN3}E_5O)+8 24 P"a~qTn)G% 25
CerA 5 45 C}2QP&a}(X@ 26 tN3}E_5N)'5n5f99e!uBv 27 r|c\tR3|Yce 28 C}2QP&a}(XA5a88jpKnH 29 qPn#C$2Pd*5 30 r|c\tR3|Ycfa37iu7w@G 31 E[5Or#c[+Ve 32 qPn#C$2Pd*632ht<cI?x 33 P"a~qTn"W(e 34 E[5Or#c[+Vf2cs;h5Hp!t 35 tN3}E_5N)': 36 P"a~qTn"W(fcn:g:4y{J 37 C}2QP&a'uU 38 P"a~qTn)G%2cs;h5Hp!t 39 tN3#Lh5D&qQBeM32ht<cI?x 40 P"a$x]nuTr}cn:g:4y{J 41 C}2TW/at|OS|X32ht<cI?x 42 P"a$x]nyKw"cn:g:4y{J 43 C}2TW/axsPZ5a88jpKnH 44 qPn&J-2M^vN|2cs;h5Hp!t 45 tN3#Lh5N'|MRxa3?f{;73b 46 E[5Ry,c[)NzsIn5n6?iE53 47 r|c_{[3|W[|Ev2c{8n92q!uN63b 48 E[5Ry,c[)NzsIn5nG8une 49 C}2TW/a~&PXvG32qqBge26 50 P"a$x]n#U}yGT5aA5pthab 51 qPn&J-2Qb"KtucnCd@8cp:f9EcA 52 tN3#Lh5O'|MRxa3@f{;a;4xtgac 53 qPn&J-2Qb"KtucnCd@8c|Kze25 54 P"a$x]n#U}yGT5aAFi!q54 55 r|c_{[3}Y[*3i2c|KnHa<!xd:3a 56 E[5Ry,c\+N(a<n5oI?xHN;3b 57 E[5Ry,c_tF32ht<cI?x 58 P"a$x]n,Rrtcn:g:4y{J 59 n6?iD 60 Bd@8: 61 {8n92q!uN6 62 A5ptg 63 o6?iD 64 Cd@8cp:f9E 65 qqBg3:e!t;6 66 A5pt5oIK8 67 |KnHa<!xd: 68 AHp!tlzj 69 Fi!q 70
FjM 6 19 qPn&J-2FP$M&uJ 71 P"a$x]nuTr} 72 E[5Ry,cQ(C~c6Z 73 tN3#Lh5Ev~X\+Z 74 r|c_{[3sPZwK* 75 qPn&J-2G^$Hzw 76 E[5Ry,cR)D 77 r|c_{[3vMU% 78 C}2TW/axsPZ 79 tN3#Lh5K#sPZ 80 tN3#Lh5N'|MRx 81 C}2TW/a~&PXvG 82 r|c_{[3}Y[*3i 83 qPn&J-2Sbv 84 C}2TW/a$qH 85 P"a$x]n&Ks 86 qPn&J-2T[" 87 C}2TW/a$%I\+Z 88 r|c_{[3)TPw 89
r=Ac!t;uH2xsFc7> 1 1 txDaH8w!t 90
FkB2xtIv3Gh!r;c8 1 1 Cm}5v9Fx 91
!p?p3Gi!sJaH7v!tB 1 1 r=Ac!t;uH 92
Js!rA 0 1 r=Ac!t;uH 93
qPn"QxyGnwTr}5E.6 2 5 1 0 1
8< 1 vp:fF 2 Jes:t 3 K6pz 4 Mg 5
8B 6
macro 3 0
map 4 25 AL_LOGIC_DRAM16X4 1 AL_MAP_ADDER 2 AL_MAP_ALU2B 3 AL_MAP_BLE_ADDER 4 AL_MAP_BLE_GATE4 5 AL_MAP_BLE_LUT4 6 AL_MAP_BLE_LUT5 7 AL_MAP_BLE_LUT6 8 AL_MAP_BLE_LUT7 9 AL_MAP_BLE_MULT18X18 10 AL_MAP_BLE_MULT9X9 11 AL_MAP_BLE_MUX4 12 AL_MAP_F7MUX 13 AL_MAP_F8MUX 14 AL_MAP_GATE4 15 AL_MAP_LLMUX 16 AL_MAP_LUT1 17 AL_MAP_LUT2 18 AL_MAP_LUT3 19 AL_MAP_LUT4 20 AL_MAP_LUT5 21 AL_MAP_LUT6 22 AL_MAP_MULT_ADD 23 AL_MAP_MUX4 24 AL_MAP_SEQ 25
pack 5 45 AL_MAP_LUT1 26 AL_MAP_LUT1__default 27 AL_MAP_LUT2 28 AL_MAP_LUT2__default 29 AL_MAP_LUT3 30 AL_MAP_LUT3__default 31 AL_MAP_LUT4 32 AL_MAP_LUT4__default 33 AL_MAP_LUT5 34 AL_MAP_LUT5__default 35 AL_MAP_LUT6 36 AL_MAP_LUT6__default 37 AL_MAP_SEQ 38 AL_MAP_SEQ__default 39 AL_PHY_BRAM32K__default 40 AL_PHY_BRAM__default 41 AL_PHY_CLKDIV__default 42 AL_PHY_FIFO__default 43 AL_PHY_GCLK__default 44 AL_PHY_IOCLK__default 45 AL_PHY_LSLICE__lble5_2 46 AL_PHY_LSLICE__lble6_1 47 AL_PHY_LSLICE__lble_mux4_2 48 AL_PHY_LSLICE__lseq_2 49 AL_PHY_MSLICE__mble4_2 50 AL_PHY_MSLICE__mble5_1 51 AL_PHY_MSLICE__mble_adder_2 52 AL_PHY_MSLICE__mble_gate4_2 53 AL_PHY_MSLICE__mble_mux4_1 54 AL_PHY_MSLICE__mseq_2 55 AL_PHY_MULT18__mult18x18_1 56 AL_PHY_MULT18__mult9x9_2 57 AL_PHY_PAD__default 58 AL_PHY_VPAD__default 59 lble5 60 lble6 61 lble_mux4 62 mble4 63 mble5 64 mble_adder 65 mble_gate4 66 mble_mux4 67 mult18x18 68 mult9x9 69 seq 70
phy 6 19 AL_PHY_BANKREF 71 AL_PHY_BRAM 72 AL_PHY_BRAM32K 73 AL_PHY_CENTMUX 74 AL_PHY_CLKDIV 75 AL_PHY_CONFIG 76 AL_PHY_CSB 77 AL_PHY_FIFO 78 AL_PHY_GCLK 79 AL_PHY_IOCLK 80 AL_PHY_LSLICE 81 AL_PHY_MSLICE 82 AL_PHY_MULT18 83 AL_PHY_OSC 84 AL_PHY_PAD 85 AL_PHY_PIB 86 AL_PHY_PLL 87 AL_PHY_PREMUX 88 AL_PHY_VPAD 89
pin_test_tdpack 1 1 pin_test 90
pin_test_tdread 1 1 pin_test 91
pin_test_tdrtl 1 1 pin_test 92
work 0 1 pin_test 93
AL_LOGIC_DRAM16X4 2 5 1 0 1
di 1 raddr 2 waddr 3 wclk 4 we 5
do 6
