Good afternoon! I will support the project with my contribution. I made all the improvements and went through all the steps.
1. I installed Bootloader 0.8, updater 0.2u, scope v1.00n
2. Made a copy of flash spin
3. Flash has been unsoldered
4. Soldered the jumpers between the connectors
5. I made a backup copy of the fnirsi FPGA, a photo of the flash drive and a copy of the firmware.
6. Installed FPGA
Everything worked and installed without errors.
Problems I found after installation
1. The oscilloscopes of channel 1 and 2, which are located when shifted to the left behind the screen, are not stable and do not correspond to the real signal, if the trigger is set to 75%, then a similar effect occurs at the beginning of the signal
2. The sensor in the left half of the screen does not work correctly, when pressed at the bottom, the measuring range switches instead of changing the scan time, this effect is present in several places on the screen
3. The V and T measurement cursors are very difficult to select and shift, the area where they are pressed does not work correctly, and the priority when pressing the display is not the cursors, but the waveforms.
4. If you turn on the oscilloscope when there is a signal at the input, the rays are red.
All the problems are shown in the video.
Is the generator menu not active yet? Changing the settings does not affect the output signal.
https://rutube.ru/video/private/a701d4730ecd78b6fd1e1ea21f9cd548/?p=1aHaMPT_wu71vYz-bQ2eNwhttps://rutube.ru/video/private/6437dd32f557c4b24e5e8dc1d788bd58/?p=FLfn8t8VMPPY5jOLYY9_LA
