Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
FNIRSI 1013D tablet scope - display issue or normal behavior ?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: FNIRSI 1013D tablet scope - display issue or normal behavior ? (Read 416 times)
pfm
Regular Contributor
Country:
on:
March 30, 2024, 02:56:29 am »
Just got a 1013D and have a couple of questions on what to expect from the display. The manual is of no help in this regard.
- When the time scale is changed to 100ms/div or higher the bottom measurement panel (where it displays Vpp Vrms Freq etc...) disappears. It appears only from 50ms/div or lower. Is there anyway to lock it for high time scales as well ?
- On very small signals (~10mv) when the vertical scale is changed between 100mv/div and 50mv/div there is no difference in the size of the waveform. But on slightly larger signals even like 100mv or more it works fine. Is this a defect ? Or is there some issue related to its minimum amplitude resolution ? What adds to the suspicion is that when it is switched between 100mv/div and 50mv/div I dont hear the relay click like I hear when switching between other ranges so surely its doing something different for 50mv/div.
Logged
Atlan
Frequent Contributor
Country:
Re: FNIRSI 1013D tablet scope - display issue or normal behavior ?
Reply #1 on:
March 30, 2024, 06:08:07 pm »
1. switched between 100mv/div and 50mv/div
This is a software issue, data from the 100mV range is multiplied by 2
2. When the time scale is changed to 100ms/div or higher the bottom measurement panel (where it displays Vpp Vrms Freq etc...) disappears. It appears only from 50ms/div or lower. Is there anyway to lock it for high time scales as well ?
Property of the original firmware, it cannot be changed.
https://www.eevblog.com/forum/testgear/fnirsi-1013d-100mhz-tablet-oscilloscope/2150/
Logged
FNIRSI 1013D Always provide a picture or video with the problem where the parameters of the oscilloscope are visible, and a picture of the diagnostic screen with the values.
pfm
Regular Contributor
Country:
Reply #2 on:
April 03, 2024, 11:27:05 pm »
I want to correct/add one piece of information in my original post -
I said the second issue happens only for small amplitude signals. That is not true. It happens for any amplitude signal. Basically at and above 100ms/div when you switch between 100mv/div and 50mv/div there no difference in the amplitude of the displayed waveform. I would expect the waveform to double or halve based on the selection but it just stays the same. I think this is a bug in the software/firmware. Is this issue fixed in the github firmware ?
Question # 3 - what is the minimum signal this scope can detect ? Looks like it may be about 10mv ? Isn't that too high as compared to other entry level scopes ? I thought it would be around 2mv ?
Last Edit: April 03, 2024, 11:31:14 pm by pfm
Logged
Atlan
Country:
Reply #3 on:
April 04, 2024, 05:05:14 pm »
Sensitivity is 100mV/div. 8bit ad converter. 800mV /256 is 3,1mV per bit. Interference is 1-2bit. Maybe 2x3,1 is 6mV and more.
Logged
pfm
Regular Contributor
Country:
Reply #4 on:
April 05, 2024, 01:04:53 am »
yeah by my measurement its like about Vrms 8-9mv. Below that it does not register a good stable wave or any voltage or frequency measurement value.
This for signals under 40khz only as I was using a soundcard for a test signal.
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
