Author Topic: Fnirsi current clamp.  (Read 662 times)
Online RAPoTopic starter
« on: December 06, 2024, 04:11:00 pm »
Fnirsi has a new toy on pre-order: a current clamp. See here.
Offline Paul T
  • Mechanical Integrity Engineer
Re: Fnirsi current clamp.
« Reply #1 on: December 06, 2024, 04:33:35 pm »
"Pre-sale officially started, and delivery is expected to start in mid December. Use code DMC10 to get extra 12% discount"
It says it has 10,000 counts, but the images show current measured with less precision.  Wondering if it's a good value vs the Uni-T UT201e.  I need to see down to single-digit mA resolution on DCA usually.    There are other players at this price point that do not perform as well as the Uni-T, such as GVDA and it's cousins.
Electronics always a core hobby. Sometimes I blog at KeepOnTesting.
« Reply #2 on: December 06, 2024, 04:39:58 pm »
Yes the unit is a gem. I've pushed the order button with the coupon code. Hope it arrives this year.
Offline jfiresto
« Reply #3 on: December 06, 2024, 04:51:32 pm »
... I need to see down to single-digit mA resolution on DCA usually....
Its stated accuracy suggests that will be a challenge:
-John
Online coppercone2
« Reply #4 on: December 06, 2024, 05:02:48 pm »
If you can loop the wire, you effectively double your measurement
Online nctnico
« Reply #5 on: December 06, 2024, 07:02:02 pm »
I hope this is sarcasm...  :)
The following users thanked this post: egonotto, KungFuJosh, RAPo, cte
Online DaneLaw
« Reply #6 on: December 06, 2024, 07:36:36 pm »
There is a world of difference between the low current clamp like 210E, and the high ones, like this 600A unit.. they are optimized for different use-cases, and the ones that will do 600A or 1000A are usually close to useless for mA in the single or double digits from their hall sensor clamp.
Prefered to get one for each scenario.. a unit for low, and a unit optimised for high amp values..
« Last Edit: December 06, 2024, 09:03:36 pm by DaneLaw »
The following users thanked this post: RAPo
« Reply #7 on: December 07, 2024, 08:25:33 am »
No it is a terrible typo on my side.
The intended reply was:
Yes the uni-T is a gem.
The following users thanked this post: nctnico, KungFuJosh, BILLPOD
Online Aldo22
« Reply #8 on: December 07, 2024, 10:13:01 am »
Would you prefer the UT201E to the Owon CM2100?
If so, why?
The Owon has 20000 counts and a similar precision in current measurement afaics.
https://static.eleshop.nl/mage/media/downloads/CM2100-Clamp-Ammeter-UserManual.pdf
https://eleshop.eu/owon-cm2100-clamp-meter.html
« Reply #9 on: December 07, 2024, 11:20:55 am »
I have both. Both are good meters.
The uni-T I acquired first is more petite and always (somewhere) on my bench.
The owon is in the same bag as my Siglent oscilloscope.
So it is just a case of acquired preferences.
Online danno_cj
« Reply #10 on: December 07, 2024, 06:08:04 pm »
Owon CM2100 has two variants. The one with B at the end Owon CM2100B have Bluetooth connection and offline recording with 10000 counts that can be saved with the smartphone. The 20000 counts are only for voltage. This is valid also for Fnirsi, those 10000 counts are not for amperage range. Fnirsi is not made for low current measurements since the lowest value 10 mA. 50 mA on Fnirsi will be read as 0.05A  and the Owon display will show 0.050A. The last digit on the all multimeters cannot be trusted regardless of how expensive it is.
The only good feature of Fnirsi is dual display with voltage and amperage values on the same time. Like the all devices from this brand have fancy display that is irresistible for novice users.
Offline BILLPOD
« Reply #11 on: December 07, 2024, 07:35:28 pm »
If so, why?
I have the Owon CM2100B, and love the Bluetooth function and the app for cell phone.
Other than that, it is very similar to my UT210E :horse:
