Also got one, first impressions are mediocre.
Purchased it on sale from a store on Aliexpress (36$ delivered incl.25%EUVAT)
Dont like the connector, there is likely a reason why they tend to use specialty connectors where some seem to originate from aviation on cheap resistance/milliohm meters.
Is it a GX12-4pin on HRM-10?
Trying to find heads & tails of the different models.
* Yaorea 1030+ USB-A 4pin
* Yaorea 1035+ XS10 4pin?
* RC3563 GX12 4 pin?
* HRM-10 GX12 4pin?
* Yaorea 2050 USB-A 4pin
Correct?
Why you say yours is mediocre? in what scenario's? I find mine really competent in diagnosing lithium batteries health, it's easy to find a failing or bad cell in a pack. The cable is really not good, and the clip solution is not adequate for bare cells, the pin type is better but the device reads fast and comparing to hioki BT3563A and BT3554 it does not disapoint.
ITs still early days, but there was a few things that didn't appeal..
The lack of silicone wires for its 4-wire inner measurement wires, which we even see on 5 dollar 4-wire test grippers... it makes the cable rigid and will have a will of its own when you try to measure, also very little spacing from one grapper to the next if you wanna center a battery, and poke it from each side.. you have very little play, - as mentioned also don't like the screw-on connector that you need to align and carefully see where the small grease is with some light to align it correctly, it makes the product bulky, as you tend to leave the connector on, and it's cumbersome to change if you wanna make your own test leads, and the fact that it only exists with grappers, - far from ideal in most of my usecases, not least on batteries and if they wanna use this bulky connector with such a rigid short cable. put the socket in the bottom.
My unit arrived with v0.4 but hopefully, it can be suited up with other test leads, as my readings (at times) left a lot to be desired, but it's far from ideal to use grappers on fx 18650, even though you space them.
Was the socket-identification above of the different models correct, and if so, same pinout as fx RC3563?.
