New 1.09 firmware is available.
"20250415
1.0.9
--1. Fixed 10M measurement failure bug'
NPN transistor legs still with wrong recognition.
Got my unit with FW v1.07.
It can't identify the NPN transistors pinout correctly.
It is incapable to identify the Collector and the Emitter. It keeps telling me that a C is a E and vice-versa.
As others reported above, the firmware version
1.09 did not fix this issue.
It keeps telling me that the Collector is the Emitter and vice-versa,
as long as the silkscreen label is facing the user. However, if I flip it around, then it will match the correct pinout.I am using the upper second column of slots 1,2,3 to insert the DUT. Same result using the 1st column of 1,2,3 slots, or the lower 1,2,3 slots.
The first transistor I tried was a plain vanilla TO-92 2SC1815GR NPN transistor - Got a wrong pinout.
The second one is a TO-92 2N5551B NPN - Again got a wrong pinout.
I stopped there as I do not have spare time to keep checking this unit for now.
I was checking the results against a cheap Multi-function tester TC1, and datasheets to be sure.
How hard is to identify a Collector and a Emitter in such a generic NPN transistors?
What special specification the above NPN transistors have that is causing confusion on the Fnirsi tester?
As it is, the LCR-P1 can not be trusted to check transistors.
It is a pity because I really like the design and the alleged ability to measure Zenner diodes (did not test it so far, I am afraid of what I might find).
Note: I also own a Fnirsi LCR ST1 tweezers and so far I could not find issues using it.
Pictures:
2SC1815GR_facing_wrong: 2SC1815GR with silkscreen facing user - TC1 reads the pinout correctly, while LCR-P1 confuses E and C.
2SC1815GR_OK_pinout: 2SC1815GR with silkscreen facing user - Pinout correctly identified by the TC1 meter.
2SC1815GR_wrong_pinout: 2SC1815GR with silkscreen facing user - Pinout incorrectly identified by the LCR-P1 meter.
2SC1815GR_flipped_OK: 2SC1815GR with silkscreen flipped around - Both meters correctly identified the pinout.
2N5551B_facing_wrong: 2N5551B with silkscreen facing user - TC1 reads the pinout correctly, while LCR-P1 confuses E and C.
2N5551B_OK_pinout: 2N5551B with silkscreen facing user - Pinout correctly identified by the TC1 meter.
2N5551B_wrong_pinout: 2N5551B with silkscreen facing user - Pinout incorrectly identified by the LCR-P1 meter.
2N5551B_flipped_OK: 2N5551B with silkscreen flipped around - Both meters correctly identified the pinout.
FNIRSI_FW_V_1.0.9: My unit running firmware 1.0.9.
By looking into the pictures, we can see that the LCR-P1 is not checking which pin is the Collector - It just defines a slot number as being the Collector, no matter how you insert the DUT into the slots. This indicates that the programmer is not coding the required routine to identify where the Collector actually is.
Just my opinion, I might be wrong, as well they are identifying the NPN pinouts.
