A question for all users of DSO-TC3. Can you perform the following actions?
1. Take an electrolytic capacitor (e. g. 100 μF) and test it on the component tester.
2. Connect a low Ohm resistor (5..10 Ohm) in SERIES to the same capacitor and test again.
Will the ESR difference correspond exactly (within ~10%) to the additional resistor?
On my device:
220 μF 63 V Samwha SD: 209.2 μF 0.08 Ohm.
The same capacitor + 8.98 Ohm 0.5% resistor: 211.3 μF 1.2 Ohm (!!!). How on Earth?
On an old ATmega based component tester:
The same capacitor itself: 206.1 μF 0.19 Ohm.
With the resistor: 208.0 μF 8.49 Ohm. Slightly low (the correct value should be around 9.1 Ohm), but still reasonably close to truth.
The resistor itself displays 9.0 Ohm on BOTH TC3 and the old tester.
W. T. F.
