Once upon a time,Oscilloscopes did not have any way of changing the volts/div setting to match a probe,so if you used a "X10" probe.the displayed voltage would be a tenth of that which the user might expect.
At that time,however,Engineers & Technicians were equipped with a very useful accessory,called "a functioning brain".
Using this amazing device,they were able to multiply the reading by 10 in their heads,& had very little difficulty in using X1,X10,or even X100 probes.
This was obviously an unsatisfactory state of affairs,so 'scope manufacurers devised probes which told the Oscilloscope to multiply the reading so the user didn't need to!
This brought about confusion,as people persisted in using the old style probes,& having switched off their brain,started to get confused,as they expected the Oscilloscope to do their thinking for them!
+1
And many that acquire CRO's as their first scope quickly learn this is the case and many threads here attest to this fact. That some also have this affliction with a DSO that does all the work for them I also find amusing.
But we have all done it ourselves in our early days, those that haven't are liars or have bad memory.
I still find myself counting graticules and portions of. A reminant of times past I guess.
With the old style CROs,any confusion was usually only for a few minutes,as commonsense asserted itself(or the Boss slapped you over the ear!
The first thing you did if you got a "funny" display amplitude was to look at "Cal Out" on the 'scope.
If that was wrong,too,suspicion went straight to the probe.
Of course,switchable 1X/10X probes were pretty much unknown in those days!
Rigol,obviously meant well in making the X!/X10 function switchable on the 'scope,but they may have been better to have left the "volts/div" unchanged.
Alternatively,they could have included "X10" or a distinctive colour in the "volts/div" display,or lit up an LED alongside the BNC input for whichever channel is selected as "X10".
Unfortunately,people see more expensive 'scopes with automatic "volts/div" switching from the probe,& naturally assume their cheaper unit has it as well.
I don't really like the Rigol display,with so many parameters shown on screen.
It seems "cluttered",with no parameter seemingly given any priority .
Of course,this is from screenshots---using it in "real life" may be very different,as you quickly learn to ignore what isn't of immediate concern.
