Author Topic: Free HP3478A multimeter control program.  (Read 25734 times)
Offline Miti
Re: Free HP3478A multimeter control program.
« Reply #75 on: February 19, 2023, 08:32:02 pm »
Hi Luke,
I have Kaspersky free installed on my computer and all of a sudden today, after years of having and using your software, Kaspersky deleted multiple version of this application because it thinks is infected with VHO:Trojan.Win32.Convagent.gen. I tried to download it again from your site and it doesn't let me.
Do you know what can cause this? Something in the SW behavior that looks like a trojan, or Kaspersky went crazy? Real trojan?
Thanks,
Miti
Fear does not stop death, it stops life.
Offline Miti
« Reply #76 on: February 20, 2023, 06:30:07 pm »
Now it won't even allow me to download anything from your site. It says:
"Visiting a dangerous website has been prevented"
What is going on? Has Kaspersky gone nuts? Can other people check with different antivirus SW?
https://mesterhome.com/gpibsw/hp3478a/Software/
Thanks,
Miti
Offline coromonadalix
« Reply #77 on: February 20, 2023, 07:34:05 pm »
kill your  A.V  and retry  ???
« Last Edit: February 01, 2024, 06:32:17 pm by coromonadalix »
Offline lmesterTopic starter
    • My page
« Reply #78 on: February 20, 2023, 07:44:29 pm »
I had the same problem with Windows Defender a few years ago. I reported the problem to them and they published a revised virus scan file to correct the problem.
Here is a link to report to Kaspersky:
https://forum.kaspersky.com/topic/kaspersky-how-to-report-false-positive-22328/
« Last Edit: February 20, 2023, 07:48:19 pm by lmester »
    • My page
« Reply #79 on: February 22, 2023, 07:39:00 pm »
I tested my program files on my work computer. It's running Microsoft Defender for Endpoint. This is the enterprise version of the microsoft security software. No virus was found in the files. Definitely a false positive.
The following users thanked this post: Miti
    • My page
« Reply #80 on: January 23, 2024, 06:15:09 pm »
I have users of my HP 3478A multimeter control software that are getting checksum errors when trying to read the calibration data. This is happening with newer AR488 firmware versions. Older firmware works fine.
My program works with AR488 0.49.14 but fails with AR488 0.51.18.
If you have checksum fails you should check your firmware version. You may need to downgrade until I find the cause of this problem.
The following users thanked this post: coromonadalix, adinsen
« Reply #81 on: January 23, 2024, 06:23:29 pm »
Same here,  no problems with antivirus  and  downgraded the firmware ...  but not using 3478, im using other 344xx series
Offline adinsen
« Reply #82 on: February 01, 2024, 03:59:50 pm »
Your software made my day! I bought a 3478A a few weeks ago and was becoming anxious that the battery would run out as it was older than I thought when I bought it. The battery is impressively still at 3.5V even though its date coded 11/87. So I was happy when I received the PCBs for AR488 today from JLCPCB, I got the 24pin connectors from Digikey earlier this week.
As you note above, I had to install AR488 0.49.14 firmware from the archived ZIP file in the github repository to make it work. I checked the AR488 issue tracker https://github.com/Twilight-Logic/AR488/issues?q=is%3Aopen+is%3Aissue and there's apparantly nothing reported there about the problem. We should. Is there a way to dump the communication between your software and the AR488 for debugging?
The automatic GPIB address search and edit calibration data dialogue are very nice features of your software!
I've observed a bug that sometimes it display Ohms instead of DCV. Clicking the function radio button corrects the display, so it's just a minor source of confusion. See screenshot.
Thanks a lot for your work  :-+
/Anders
Offline ultrasmurf
  • Country: sg
« Reply #83 on: April 08, 2024, 09:54:09 am »
Hi guys, just scored a cheap working 3478A. And after failing to write program to talk to the gpib I stumble to this program. Now I need some help because it seems that the gpib is only somewhat working (this is definitely the reason i fail to write the program... not my programming skill.... ;))
If I use this beautiful program, and set my gpib address at 6 (seems to be the value of the setting for the software as downloaded), it can somehow connect to the multimeter. I need to press the reset button, and then i can press the start button and get it to read the measurement and display it on the software.
During start up the software recognize the com port and set it correctly but will fail at detecting gpib.
If I press reset, it will say comm failure, but I can hear clicking in the multimeter, and after this if i press start button it will display correct measurement.
If I try to read cal data it will say comm fail.
If I set my gpib address to anything other than 6 I can still hear the multimeter responding when I click reset, but it will not allow my to start and will only show comm fail.
Any pointer as to where I should look at ? Or way to test the gpib ?
Thanks a bunch...
Offline ultrasmurf
  • Country: sg
« Reply #84 on: April 09, 2024, 02:45:28 am »
Just a quick update,
Ofcourse everything now works... no idea what was it. Might be the PC. Now it scan and found the gpib address and communicate with the multimeter like a champ. Reading calibration data without issue.  :palm:
Offline adinsen
« Reply #85 on: April 09, 2024, 04:25:09 am »
Great to hear! Mine sometimes takes a few tries before I get it to connect. I think it's the windows stack of COM-USB drivers but once it's working, it's rock-stable.
Offline porter
« Reply #86 on: November 14, 2024, 02:59:53 am »
I recently installed the Wine program  on my Ubuntu 24.04 system so I could use LTspice. Since LTspice worked (after I realized the installer placed the files
in an unexpected location), I thought I would try the HP3478A Instrument Control Software.  To get the HP3478A program up and running the COM port had
to be mapped to the AR488 port. Wine has a regedit program and instructions to re-map the ports from the Wine defaults.
I've attached a screen shot of the key/values that I added.
So it looks like it works. I used the calibration export and data logging features. The large numeric characters on the screen are a little clipped.
I may be able to change the Wine configuration for the HP3478A.exe program to fix it.
“It’s all very simple, or else it’s all very complex, or perhaps it’s neither, or both.”
— Ashleigh Brilliant
    • My page
« Reply #87 on: November 15, 2024, 03:10:31 pm »
If you're still having problems with the meter display I can put up a version of the proram with a smaller font.
