Wouldn't a standard 1:100 oscilloscope probe with a BNC adapter do the trick?
I made a buffer from vintage sw receiver vfo to a PLJ_0802-C frequency display (with IF Offsets).It is just a FET- Bipolar HiZ to 50 Ohm with a RG 174 coax to the display in another chassis.input level 50 to 200 mV.
Quote from: mag_therm on November 09, 2022, 03:32:01 pmI made a buffer from vintage sw receiver vfo to a PLJ_0802-C frequency display (with IF Offsets).It is just a FET- Bipolar HiZ to 50 Ohm with a RG 174 coax to the display in another chassis.input level 50 to 200 mV.Which FET- Bipolar HiZ did you use?Bill
