Author Topic: Frequency counters operation  (Read 835 times)
Offline Y2KEDDIETopic starter
« on: March 04, 2023, 04:12:54 pm »
I’ve noticed some frequency counters, when no signal is applied to the input, the display reads all zero’s, as one would expect.
Some counters display random readings, until a signal is applied, or the reset button is pressed. This is the case of a high resolution counter I bought from  e-bay. The operation literature say’s Radom display is normal operation.
Why do some counters require a manual reset and others don’t.
« Last Edit: March 04, 2023, 04:15:05 pm by Y2KEDDIE »
Offline pcprogrammer
Re: Frequency counters operation
« Reply #1 on: March 04, 2023, 05:10:33 pm »
Open input sensitive to noise?
No proper power on reset in the circuit?
Offline shakalnokturn
« Reply #2 on: March 04, 2023, 05:10:47 pm »
I suppose it has something to do with the way they trigger and surrounding EMI.
Offline xrunner
  • hp>Agilent>Keysight>???
« Reply #3 on: March 04, 2023, 05:30:51 pm »
If the input isn't terminated, then it's going to receive signals from the environment at the center pin of the input connector, however poor of an "antenna" that tiny piece of metal is. Now, they may be very small signals or they may not be - it depends on your local environment and the sensitivity of the unit. Try terminating with a 50 ohm termination and see if the random signals stop.
Offline edpalmer42
« Reply #4 on: March 04, 2023, 06:59:18 pm »
The other thing you can do to suppress the garbage displays is to move the trigger level slightly off zero.  It won't affect a normal reading since the input will hopefully be at a much higher level.  Note that this type of garbage display could be caused by either external signals or internal noise or a combination of both.
Ed
Offline factory
« Reply #5 on: March 04, 2023, 07:07:40 pm »
This is normal for some of the prescaler/divider ICs, for example the Plessey SP8703, which will self oscillate with no input, it can be fixed by adding a resistor to one of the inputs, but this reduces the sensitivity.
