Hi All
My last Plea for help, I have posted a couple of emails about the issue. The Windows could not start because the following file is missing or corrupt \WINNT\SYSTEM32\CONFIG\SYSTEM. I took the top off and I have a Compact Flash drive with the following information on it. Part No. 1303.0417.07, Flash Disk for R&S FSP with Windows XP.
I don't have a Windows build embedded XP disk, or the analyzers build software and R&S have told me they can't help. If only I had a friend who works in their repair\service department.
Could I just install a standard Windows XP build and install the firmware which I believe is still on the R&S website? https://www.rohde-schwarz.com/firmware/fsp40/
I would need to know on the old drive as I can still read the drive if I put it in a caddy, where the calibration data is for it.
Otherwise, the unit is a dustbin job.
Any help would be much apricated.
Regards
Paul P
I just need to understand what I need to do for the rebuild and I am sure I can sort this, i hope.
This is the system32 files of the 1.2 gig iso link of ealier threads, extract them on a usb key and make windows search manually for them
I just need to understand what I need to do for the rebuild and I am sure I can sort this, i hope.This is the system32 files of the 1.2 gig iso link of ealier threads, extract them on a usb key and make windows search manually for themTo rephrase coromonadalix's advice: Extract the system32 folder from that archive (ignore the other folders for now), and for each of the unknown devices in Device Manager, select search for driver, select manually search and select the system32 folder as the folder to search. If you need even more detailed step-by-step instructions, maybe it would help to have someone more experienced in setting up Windows XP to help? This has very little to do with the spectrum analyzer and is just setting up Windows XP with obscure drivers.
It should at least install drivers for some of the unknown devices, if not all of them.
Thernet Controller
PCI Device
PCI Simple communication
Video controller
Video controller (VGA Compatible)
I am still not 100% sure where I get the actual software for the FSP40 spectrum analyser? I know I can get firmware from the R & S website but is that only firmware.
Did do a search for the INF files and tried installing from the system32 folder. But these are the motherboard drivers not the the actual R & S hardware modules.
Hi coromonadalix
Your not rude at all, unfortunately there isn't a document, which takes you through the process and what image works with which FSP40.
VID and PID, I have not delt with before, so yes, a learning curve.
I only put a question out in this feed, https://www.eevblog.com/forum/repair/rohdeschwarz-fsp-hdd-defect/ this was to Jorg.
You are lucky you had many pieces of equipment to get the drivers from. I don't unfortunately.
I tried the XP image and put this on a spare drive, but after selecting the analyser from the list, not the backup on the startup screen, i get the blue scrreen.
I could try the NT version, but I can't open TIB files, some sort of backup.
Regards
Paul
