Author Topic: FSP30/40 embedded windows xp for spectrum analyzer.  (Read 1003 times)
Offline g7kbr67Topic starter
« on: November 11, 2022, 09:18:33 am »
Hi All
After following a previous message on the group regarding a failure of a drive in a Rohde and Schwarz FSP40.
I have a FSP40 which when boots saying, I have a missing file (Windows boot-up).  I took the top off and I have a Compact Flash drive with the following information on it.
Part No. 1303.0417.07, Flash Disk for R&S FSP with Windows XP.
Can I purchase a standard compact flash drive?  Is it a 32GB one?
Also Is the build the same ISO available for download on this site?  From K04BB's website. http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=Rohde_Schwarz/Rohde_Schwarz_FSP?
See photos below.
Regards
Paul
Re: FSP30/40 embedded windows xp for spectrum analyzer.
« Reply #1 on: November 17, 2022, 09:02:42 am »
Update
Hi have tried using the image on this original message, I am using a USB stick as the boot device with the image on.  But I get a blue screen when it boots, " A problem has been detected and windows has been shut down to prevent damage to your computer"
I have attached the jpg to the message.
Regards
Paul
Offline coromonadalix
« Reply #2 on: November 18, 2022, 03:37:06 pm »
how did you extract this iso ??    power iso, ultra iso  have settings for boot device iso sources ...
or you could re-install from scratch  if you have  mobo bios access and put an bootable device like an cd-rom
recover the missing drivers afterwards  ???
« Reply #3 on: November 21, 2022, 07:55:59 am »
Hi
I used Rufus to build the USB stick, when you say install from scratch. I could use a CDROM drive and build the Embedded Windows OS.  But I am not sure what version and where to get it from?  I have the original Compact Flash drive which I hope has the calibration data on it ok.  Can the firmware still be download from a site for the build on a fresh version of embedded XP.
Regards
Paul
