Author Topic: Power supply recomendation  (Read 852 times)
Offline rauldmTopic starter
  • Country: mx
« on: June 30, 2021, 08:16:25 pm »
Now I'm calibrating servo motors based on BLDC motors, I'm zeroing the Resolver sensor, for this work I need feed two phase of motor for locking the rotor, I'm using a power supply Agilent E3631A, on 6V-5A output can lock very fine the motor while I lock the resolver's rotor, I'm recibing other brand of motor named MOOG, when I try to locking, the rotor with this power supply is not lock very strong, this generate an angle offset error in calibration procedure. I bought a chinese switching power supply 30V-10A, but noise generated on power supplly is induced to resolver output, I see all noise reflejated on oscilloscope is more difficult calibrate. I found an economical power supply with next highligts:
-Two output with 30V-5A, an aditional with  5V-3 A.
-Encoder type knobs.
-series and parallel mode, serie: 62V-5.1A, parallel 31V-10.2A
-Very interesting thing for me, OVP/OCP/SENSEFUNCTION this turn off output when exceding set voltage or current.
-toroidal type transformer, I sent an e-mail to fabricant.
-output on off botton for each channel except 5 V fix channel.
The model is : MATRIX TECHNOLOGY MPS-3005H-3
attach video link
Someone know about power supply brand?
Someone has an experience with this brand?
Regards.
