Hello All,
meanwhile, i managed to get the device to do something ;-)
the following parts have been defect:
- input double JFET, replaced with 2N5909
- defect LT1012, actual replaced with OPA177
- defect trimpot R348 and R314
- defect -5V regulator LM337LZ
- defect MPS-U60 PNPs in the end stage (Q303, Q305 and Q307), replaced with MJE350
Parts that have been replaced, but have not been defect:
- all electrolytic caps
- MPS-U10 NPNs in the end stage (Q301, Q304 and Q306) have been replaced by the MJE340, so they fit to the MJE350
Now the instrument is in the status, that it shows real values and no nor "OL" in all ranges. Voltage works fine, but I'm not sure, what's with the input impedance. I have bought 10 2N5909, and selected the one, with the lowest leakage current. I measured the leakage current at 5V reverse voltage with my 616 electrometer. The measured current varies from about 2pA to 0.2pA.
I will replace the input OP with the original LT1012, when they arrive here.
With the input double JFET's I'm currently not sure, if I want to keep close to the original design with the double JFET, or switch to a modern OP like the ADA4530 or so. If I go to the ADA4530, this will also replace the LT1012 ...
So at the next weekend I will continue with the performance check first before I do further modifications - luckily I also own a 263 current calibrator with good performance, so it will also easy to check the lower current ranges.
I will update you here, how it goes on with repair / performance check.
Guido
