Author Topic: Fuse Already Blown?  (Read 1352 times)
Offline brocklesTopic starter
Fuse Already Blown?
« on: February 04, 2023, 02:32:41 pm »
Put an old 87V in series with a 4mA DC source and I got no readout, then realised the meter was in AC(default). I'm pretty sure the fuse wasn;t blown prior to this but maybe mistaken. Is it possible by being in AC that it blew the fuse when it was a DC current? I'm convinced the fuse wasn't blown before.
Offline Excavatoree
Re: Fuse Already Blown?
« Reply #1 on: February 04, 2023, 02:48:28 pm »
I don't see how a 4ma source can blow a .44 ampere fuse, regardless of the setting of the meter.  Even in "off" mode, the fuse can be blown with too much current, but current lower than the fuse's rating won't.
Unless your source is defective or otherwise putting out more than 4 ma.
Are you sure the fuse wasn't blown before?
The following users thanked this post: brockles
« Reply #2 on: February 04, 2023, 02:54:15 pm »
 |O  Opened up the meter to remember I'd taken out the fuse for another meter a few years ago  :palm:
Please can someone delete this post
The following users thanked this post: Alti, luudee
Offline Excavatoree
« Reply #3 on: February 04, 2023, 03:25:32 pm »
I believe you can delete it.
You were correct, however.  The fuse was not blown, because it wasn't there.
Offline themadhippy
« Reply #4 on: February 04, 2023, 03:37:59 pm »
But how do you know its not blown in its alternative location?
Offline Excavatoree
« Reply #5 on: February 04, 2023, 04:59:39 pm »
There are many fuses in many locations - some blown and some not.  How does one know which fuse is for the meter?  Is the the one that was last removed, or the one that will be installed?
Offline extremgear
« Reply #6 on: February 04, 2023, 09:41:08 pm »
Maybe the current was higher than 4ma .
Depending of your supply, if it was set to 4ma with a high voltage and then plugged to the meter the current was probably higher than 4 ma during a short time .
Offline BillyO
« Reply #7 on: February 04, 2023, 10:06:24 pm »
The current was 0 the entire time.  There was no fuse in the meter.
Want to see an old guy fumble around re-learning a career left 40 years ago?  Well, look no further .. https://www.youtube.com/@uni-byte
Online tv84
  • Country: pt
« Reply #8 on: February 04, 2023, 10:17:03 pm »
You should increase your current source in order to overcome that fuse absence!
The following users thanked this post: luudee
« Reply #9 on: February 05, 2023, 09:55:03 am »
Schrödinger's Fuse...   :popcorn:
Offline Gyro
« Reply #10 on: February 05, 2023, 11:04:04 am »
I don't think Schrödinger considered the 'forgot to put the cat in the box' scenario. :D
Best Regards, Chris
« Reply #11 on: February 05, 2023, 01:17:35 pm »
Maybe he should have!
Offline BillyO
« Reply #12 on: February 05, 2023, 01:41:10 pm »
Offline Kean
    • Kean Electronics
« Reply #13 on: February 05, 2023, 04:18:02 pm »
I think that upping the current source compliance voltage sufficiently to jump the distance of the missing fuse is the solution  :scared:
« Reply #14 on: February 05, 2023, 07:55:21 pm »
