Author Topic: FY6600 - 60MHz - bug reporting ???  (Read 1242 times)
Offline softfootTopic starter
« on: October 26, 2018, 11:39:50 am »
I have one of these and, for me at least, it is good value for what I paid.
The PC software is v6.0 and the firmware is v3.3 and seems to have provision to update the firmware on line.
I have discovered one problem - the PC S/W only talks to CON1 to CON16 - my system goes up to 24!! so using it requires a certain ammount of "fafing" about to get it to connect. It does have an "autoconnect" feature but it dioesnt seem to work above 16.
Has anyone found a way to report such bugs ???
TIA and best regards,
Dave
Grumpy Old Software/Hardware Engineering Git
Dave
Online rhb
Re: FY6600 - 60MHz - bug reporting ???
« Reply #1 on: October 26, 2018, 05:56:28 pm »
ROFL!!!
You must be kidding.  Your chance of getting a "bug/feature" fix from Feeltech is identically zero.  But you can try contacting admin@feeltech.net is you're feeling masochistic.  They will promise lifetime support, but that person has already died, so the support has ended.
« Reply #2 on: October 26, 2018, 07:11:21 pm »
PMSL - much as I expected ;-)
Dave
Dave
Online TheSteve
  • Living the Dream
« Reply #3 on: October 26, 2018, 07:29:36 pm »
Probably not so much a bug as a limitation of the development software they used - VB6 maybe?
VE7FM
Offline malagas_on_fire
  • Country: pt
  • Kernel Panic
    • Malagas Lair
« Reply #4 on: October 26, 2018, 10:26:28 pm »
Can you go to Device Manager , Com Ports and right click. Then go advanced and change Com number
If one can make knowledge flow than it will go from negative to positve , for real
« Reply #5 on: October 26, 2018, 10:29:44 pm »
I didn't know you could do that!
You cannot do that as it b*****s up bluetooth device handling :-(
The only thing you can do is change the com port to one that is free (and below 16)!
Oh well - worth a try I suppose
Dave
« Last Edit: October 28, 2018, 12:25:25 pm by softfoot »
Dave
