Products => Test Equipment => Topic started by: pascal_sweden on April 14, 2017, 12:36:35 pm
Title: GAOTek Announces Ultra Portable and Versatile Digital Oscilloscope
Post by: pascal_sweden on April 14, 2017, 12:36:35 pm
http://www.prweb.com/releases/2017/04/prweb14207659.htm (http://www.prweb.com/releases/2017/04/prweb14207659.htm)
(http://ww1.prweb.com/prfiles/2017/04/02/14207659/gI_65008_oscilloscope.png)
Title: Re: GAOTek Announces Ultra Portable and Versatile Digital Oscilloscope
Post by: Daruosha on April 14, 2017, 01:17:59 pm
Looks like a toy rather than a proper handheld tool. I wonder how much crap it's going to be, just by looking at the design of the layout and the screen type and information displayed on it.
It's surly a joke.  Isn't it?
Post by: nctnico on April 14, 2017, 01:27:51 pm
Let's not kill new design ideas off the bat! The French company Metrix came up with this a long time ago:
(http://sigma.octopart.com/10671540/image/Metrix-Electronics-MTX1032-C.jpg)
The GAOtek 'scope' seems to be more like a DMM with logging capabilities than a real oscilloscope though.
Post by: Fungus on April 14, 2017, 02:42:15 pm
Total lack of tech specs?
Post by: kripton2035 on April 14, 2017, 02:48:23 pm
Technical Specifications
Display   320 ´ 240 LCD   Display area   3.07x 2.28 in(78 mm x 58mm)
Backlight   White or yellow   Input impedance   DMM 10M??
Battery   Built-in1600mAh Ni-Hi battery   Auto power-off   No action within 10mins
Low Battery indicator      Charging time   More than 8hours
Working time   Approx. 6 hours   Memory   DMM 400groups data and DSO 40 waveform record
Work condition   0~+104 F(0°C~+40°C);<75%RH   Storage condition   14~ 140 F(-10°C ~ +60°C); <90%RH
Dimension   7.87x 5.31x 2.047 in(200mm ´ 135 mm ´52mm)   weight   Approx 2.204 lbs(1000g) (Net weight)
Operate height   0~ 6561.68 foot(0~2000m)   Adaptor power   110V~250V?12V/1A, protection- switch power
Analog bandwidth   DC ~ 50MHz, probe: X10; DC~6MHz, probe X1 (3db bandwidth?sine wave response)
Max sampling rate   200Msps   Vertical resolution   8 bits
Channel   1   couple   DC/AC
Input impedance   1M?//20pF   Div   vertical ±4 div   horizontal 10 div
Vertical sensitivity range   20mV/div ~ 50V/div 1-2-5 exchanging step   Time base   10ns/div ~ 1s/div 1-2.5-5 switch
Vertical amplitude accuracy   ±(5%+ 0.1div)   Time base accuracy   ±(0.01% + 0.1div)
Auto-Zero calibrating   Yes   Measuring mode   Normal, Video, Single
Trigger level   ± 3.8 div (every step interval 0.04div)   Single slop of selection   Rising edge/ Falling edge
Trigger condition   ± 3.8div (every step interval 0.04div)   Auto setting   Auto setting time base and amplitude
Cursor measuring   dV, dt,   Auto measuring   Vp-p, +Vp,-Vp,f,,T
Auto measuring accuracy   ±(5%+ 0.1div)   Waveform   (sinx)/x
Post by: Fungus on April 14, 2017, 02:53:44 pm
I guess it all depends on price. There's already cheapo handheld stuff out there though, eg. DSO quad.
Post by: pascal_sweden on April 14, 2017, 03:51:45 pm
POJ - Piece of Junk :)
