Author Topic: Gap between probe slots in handhled DMMs  (Read 1209 times)
Offline atulraviTopic starter
  • Country: in
    • Personal Blog
« on: June 04, 2023, 08:07:17 pm »
Hello to all readers of the forum. I am currently working on a small device that will go inline between the multimeter and the probes which will help me get the measurements at ease. However, I would like to make the files easy for everyone to use. And it is a PCB that fits into the COM and DC voltage measuring port of my MASTECH MAS830L.
I know Dave's ucurrent needs cables to be fit inline, however, I want to avoid that and want to add a banana jack that has both female and male ends which will slide on to the multimeter probe slots. The device I am working on is primarily for low end handheld DMMs which are cheap as chips and are not necessarily auto-ranging.
The question is: is the gap between the ports the same on all multimeters? i.e standardised.
 (PS the gap between the ports in my Mastech is 1 cm from the larger hole - larger hole and 2.3 cm smaller hole to smaller hole.) I know the angling is not, however, what about the gaps?
Hardware builder, innovator, hobbyist, by night. Student by day. Amateur HAM radio operator (restricted) VU3FUJ.
Offline coromonadalix
Re: Gap between probe slots in handhled DMMs
« Reply #1 on: June 04, 2023, 09:14:35 pm »
i would say  not standardized on some brands
i think 19mm center to center is the "standard"  if i recall
examples,  banana to bnc plugs  etc  ...  bench meters  psu's   etc ..
« Last Edit: June 04, 2023, 09:16:18 pm by coromonadalix »
Offline bdunham7
« Reply #2 on: June 04, 2023, 09:27:52 pm »
They're almost all 3/4" from center to center but the other sizes--the diameter of the center tower and the OD of the sheath hole might vary.  If you are just using two plain banana plugs, 3/4" should get the job done.
The following users thanked this post: mwb1100
Offline mwb1100
« Reply #3 on: June 04, 2023, 10:22:46 pm »
You are showing the distance between the A jack and the COM jack - most meters have 4 jacks and I think more often than not the A jack is farther away from the COM with an intervening jack (like a mA/uA jack).  Flukes are a prime example.
You might need to think about what meters your target market will likely be using.  And regardless, many of your users will likely need to use cables to allow the device to attach.
The following users thanked this post: atulravi
Offline nctnico
« Reply #4 on: June 04, 2023, 11:48:53 pm »
I agree. 19mm or 3/4" is as good as a standard as it gets. Power supplies and DMMs typically use this spacing between 4mm sockets / binding posts.
Offline Brumby
« Reply #5 on: June 05, 2023, 12:47:34 am »
Exactly this.  ^ ^ ^
Forget the 1cm measurement you have noted above - it is irrelevant to the question you are asking.  To that question, the only important dimensions are the distance between centres and the size of the banana sockets.
The other consideration is whether you have shrouded plugs or not - which does not change the above details.  For a (near as you could get to a) "universal" solution, use unshrouded.  Mind you, there are some use cases where shrouded plugs might be "specified", but unshrouded ones would still work.  This can result in a reduced safety margin, but people have been working with unshrouded connections in those situations for ages.  But just be aware of this.
  • Country: in
    • Personal Blog
« Reply #6 on: June 05, 2023, 03:05:47 pm »
I just got around to reading all of the responses and after "thorough" analysis, I will go ahead with a small box to which banana jacks can be attached to instead of a plug and play variant since clearly, the distances between the centers of the banana jacks is not standardised. That way, it will work with more meters. Thanks a lot to all of the readers who pointed out possible issues with the spacing I chose.
Offline David Hess
  • DavidH
« Reply #7 on: June 05, 2023, 05:23:53 pm »
My favorite multimeters have the connectors in a triangle pattern so the mA, A, and volt-ohm connectors are all 3/4" from the common connector.  Some old power supplies use this configuration also to support standard 3/4" dual banana jacks.
