Author Topic: Gated shaped toneburst  (Read 1221 times)
Offline jan.diddenTopic starter
« on: December 12, 2022, 01:21:35 pm »
Hi guys, this one has me stumped. I want to generate a shaped tone burst.
A sine wave signal AM modulated, and then gated so that I get a series of say 5 sinewaves of the carrier, each of those bursts am modulated, separated by the gate zero level.
I have a two channel Siglent function generator, and I can generate the modulated/shaped tone burst, OR the gated tone burst (which actually is a sine wave modulated by a square wave).
But I can't seem to combine it.
I tried to use the gated sine wave as external input and modulate it with a sine wave but that doesn't seem te work.
Attached is what I am after. Hopefully someone has an idea how to.
Jan Didden
Online Marco
Re: Gated shaped toneburst
« Reply #1 on: December 12, 2022, 01:36:56 pm »
I don't have the signal generator, but this doesn't really make sense. The logical way to chain it is to have one channel generating a repeating modulated tone and then gate it with a square wave signal from the other channel supplied to the AUX input, not modulate it a second time.
Even if your signal generator is an expensive one with external analogue modulation input, it's better to AWG the repetitive shape and binary gate it ... which even the cheap ones support AFAICS.
« Reply #2 on: December 12, 2022, 02:26:36 pm »
I understand, and that was my first thought as well. But the you cannot gate a signal that's already AM modulated, the user interface isn't set up for that.
You can choose between gated or modulated, not both.
Maybe my function generator is a too basic model, but I have looked at other's user manuals and what I've seen is that you have only one procession selection, not two.
Unless I misunderstand you and miss something. It's happened before ;-)
Edit haven't used the ARB but I don't know if you can set it up for a sine-modulated sine.
Jan
Online Marco
« Reply #3 on: December 12, 2022, 02:43:38 pm »
That would be my suggestion, see if EasyWave can make the repeating modulated sine for Arb generation and then gate that.
« Last Edit: December 12, 2022, 02:45:13 pm by Marco »
« Reply #4 on: December 12, 2022, 03:57:35 pm »
EasyWaveX installed. I got the basic modulated sine set up, see attached.
Now I assume that if I download this to the FuncGen this will be output as a continues signal (don't have the funcgen here right now).
Now I have to figure out how to output one ' cycle'  of that, wait for am adjustable time, then the next one.
This is all new for me so apologies for thinking out loud.
Jan
Offline voltsandjolts
« Reply #5 on: December 12, 2022, 04:11:26 pm »
If you use MATLAB or Octave then this might help.
Online Marco
« Reply #6 on: December 12, 2022, 04:32:00 pm »
Looking at the manual, you can use N-Cycle mode with a trigger, use the other channel to generate the trigger.
Offline 2N3055
  • Country: hr
« Reply #7 on: December 12, 2022, 04:50:55 pm »
Jan
Hello!
What exact model of Siglent AWG you have?
Newer models all have Burst capability.
You load this very waveform you made,
enable Burst mode, set 1 Cycle (what you made is one cycle), and set repetition frequency of the burst.
Or set it to manual, where you press button to emit one burst.
Or use external trigger where you bring in trigger signal to input trigger BNC on the back of generator..
Dr. Richard W. Hamming
« Reply #8 on: December 12, 2022, 06:09:15 pm »
I have a very old SDG1020, which I already repaired once when I blew an output driver in Ch. 1.
I'm ready to upgrade if necessary.
I'll look at it again tomorrow, made some progress today thanks to you guys!
Jan
Offline 2N3055
  • Country: hr
« Reply #9 on: December 12, 2022, 06:24:50 pm »
Jan
Jan,
I took a look at user manual, and your AWG has burst mode and all the features I explained.
You should have no problems doing the steps I explained.
Let us know how it goes.
Best,
 Sinisa
« Reply #10 on: December 12, 2022, 07:01:01 pm »
A customer with one of the later X models had a similar issue with a complex waveform from which they needed a continuous waveform.
The Burst feature and it's settings is the solution.
