Well, really? Then it means that measurements by Kiriakos are wrong. http://www.ittsb.eu/GDS-2102A%20Wfms%20measurments.html
It has arrived... and yes, that green tape is our friends at Homeland Security and Border Protection having opened my box when it hit the shores in Long Beach. Go-go government bureaucracy!
(more coming later once I get home and play with it over the weekend)
According to the manual the GDS-2000A has no fine vertical or horizontal setting. Just like Owon SDS series... But Rigol, Agilent and others have fine vertical and horizontal settings.
This might be not a big disadvantage.
I can give that a whirl. Only up to a 1MHz right now but I will post the results.
Demo signal optically isolated? Why? It's unlikely.
I haven't had as much time as I would like to fart around with it of late but overall my thoughts:
1. The scope "feels" good. I like they layout of the controls. One thing I kind of wish they did was provide a rubberized ring on the outside to improve the feel of the rotary knobs a little bit.
2. I wish the traces were a little bit finer - it doesn't look like there's pixel-doubling going on but for lack of a better term the "thickness" of the traces. Not major.
3. Scope is very responsive to control changes which is great. No delays.
4. Feature-rich for the price - I mean really, I got it for ~$1700 USD for a 200Mhz 4 channel scope with good manufacture, quality components and a company that has a solid reputation here in the US.
5. As I mentioned before the responses from Instek have been top-notch. I just got a reply back from engineering on my latest complaint of not being able to remove the Go-NoGo min/max lines. They outlined the 'procedure' to remove it and added they are sending it back into engineering to make it easier (because, to be honest, what they outlined was stupid).
6. I wish I could speak more about the LA but I just have NOT had time to sit down with it yet so I can't speak to it. However, I know you can decode off the digital lines at least.
Overall, I'm really happy with the expenditure, with the caveat that I need to spend time with the LA to justify that $800 purchase. I mean for what I need it's a scope that I will be able to use for years. I completely understand that I 'overbought' on equipment - I didn't NEED 200Mhz, I didn't NEED the MSO function but it's all helpful and to be hones the price delta wasn't large enough for me to really worry about it. So for a first bench scope to replace my Pico 3206-A I'm completely satisfied.
There will be more coming once I have some breathing space to sit down and cover some more features. Between work, my kids soccer schedule and school for me I've been pretty busy. And heck, Iron Man 3 opens this weekend too. ;-)
Try how is the waveform update rate affected by turning on more channels, eight auto measurements, FFT or cursors. On my DSOX2002A it is not affected at all by anything. On the other hand, you have only 4 auto measurements + DVM, it's not much for a four channel scope.Well, my scope is 2 channel, but it could be 4 channel.
Thanks! That fills in some of the missing blanks - and the review of the LA I can easily wait for.My only other ongoing desire-to-know is: with all of the posting about interpolation / type of interpolation / affect on sampling, etc. that a number of us have been doing these last weeks, I'd like to know what a waveform looks like on the Instek when undersampled. The Rigol switches to linear interpolation - which, although a little boxy, is symmetrical - and the Agilent just makes a total mess of it (I don't even know what it's doing - but it's screwing up the samples somehow). Is the Instek still using sin(x)/x at slower sampling speeds? If so, how does it look? The test I mentioned before (with a reasonably fast sine wave) would satisfy my curiosity - whatdayasay? Huh? Puh-leeeeze? (I'm banking on your reveal of fatherhood)
Here you go - 1Mhz sine, dropped down to 10ms which gave me a 10MSPS rate, single-shot, zoomed in to 200ns. Looks like it's keeping sin(x)/x to me.
Great, thanks very much for that! Yes, it's definitely sin(x)/x - and it looks good too.I'm only wondering how you know your sample rate; I don't see it on the Instek's display.
It's under the Acquire menu (which I didn't leave up in this since it was single shot). Basically, bring up the Acquire menu and one of the buttons shows the sample rate. I upped the timebase until it read 10MSPS and then single shot it.
Oh, not really, if you work mainly with digital signals, you may rather need long 56Mpoints memory and you don't care about waveform update rate because you use Single shot most often.
